2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsEvent semantics
To: [email protected]
Date: Sat, 30 Oct 2010 03:01:32 +0200
On Freitag, 29. Oktober 2010, Andrew Johnson wrote:
> On Friday 29 October 2010 14:15:54 Ralph Lange wrote:
> >   On 29.10.2010 15:10, Eric Norum wrote:
> > > +dded to epicsEventTest and the application developers guide has
> > > been updated +to describe this requirement.</p>
> > Did you actually update the guide? At least I don't see it on
> > launchpad yet...
> Working on it, I have some uncommitted formatting changes that I want
> to keep separate that I'm also dealing with.
While you're at it, please fix the description for wait and tryWait,
they are most probably wrong. What is returned is an
epicsEventWaitStatus, not boolean. When interpreted as boolean the
return value is zero (false) if the event *did* happen
(epicsEventWaitOK) and non-zero (true) if it did not happen
(epicsEventWaitTimeout) or if an error happened (epicsEventWaitError).
At least this is what the names suggest.
Cheers
Ben
Re: epicsEvent semantics Ben Franksen
epicsEvent semantics Eric Norum
Re: epicsEvent semantics Ralph Lange
Re: epicsEvent semantics Andrew Johnson
Prev: Re: epicsEvent semantics Andrew Johnson
Next: Re: epicsEvent semantics Ben Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
