> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Friday, December 10, 2010 5:11 PM
> On Friday 10 December 2010 15:19:12 Davidsaver, Michael wrote:
> > It may be a
> > personal preference, but in the src/ directory at least I would
> rather
> > have a few large Makefiles.
> I've just pushed a partial solution to LP which splits the
> libCom/Makefile
> into a series of Makefile and RULES fragments in the various source
> sub-
> directories. See lp:~anj/epics-base/split-libCom-Makefile for the
> changes
> (which I will not merge without further discussion and agreement). I
> suspect
> that you're not going to like it though because it uses include
> statements to
> pull those fragments into the libCom/Makefile.
Unless I'm missing something doesn't moving the extra rules before the
include of configure/RULES mean that 'all' will no longer be the default
target? I tried a build and it seems to work, but I'm not quite sure
why. I see that RULES_ARCHS and O.$(T_A)/Makefile use 'all' explicitly,
but don't see how the 'all' target from RULES_ARCHS gets invoked?
While I don't really like it. Beyond this I can't see any technical
problems.
> Personally I think this
> makes
> it much easier to find the build instructions associated with a source
> file
> and vice versa.
> If we used my approach with your structure, we could maybe end up with
> build
> directories (O.<target>) and "master" Makefiles in libCom, ioc, std
and
> template (like you I'm not sure about ca). Each source sub-directory
> would
> still have a Makefile in it, and some would have RULES files as well.
> The
> disadvantage is that we would lose the ability to type 'make' in any
> source
> directory
Personally I don't see this as a serious disadvantage.
> and have it rebuild just the related libraries and products.
Your change has no effect on the target dependencies.
- Re: src/ reorganization Andrew Johnson
- src/ reorganization Davidsaver, Michael
- RE: src/ reorganization Davidsaver, Michael
<2010>
2025
2026
<2010>
2025
2026
