2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: src/ reorganization
To: "Andrew Johnson" <[email protected]>, <[email protected]>
Date: Thu, 16 Dec 2010 17:58:53 -0500
Step 1 is ready.  It builds as before with the exception of std/test
(formerly dev/testDev) which is not built and will be removed.
https://code.launchpad.net/~mdavidsaver/epics-base/reorg-src
Step 2 will be:
= split up src/ioc/as
asDbLib going to src/ioc/db and the asLib files to src/libCom/as.
= break up util
Move util/ca_* to ca/client/test/
Move util/rc2.caRepeater to ca/client/
Rename libCom/logClient to libCom/log
Move iocLogServer to libCom/log/
= Remove dependencies from ca/ on ioc/dbStatic
Move some headers from ioc/dbStatic to libCom/misc.  I think this is
just alarm.h.
Anything missing?
Unless there is are comments (or I am distracted again) I plan on doing
step 2 tomorrow.
Michael
> -----Original Message-----
> From: [email protected] [mailto:core-talk-
> [email protected]] On Behalf Of Davidsaver, Michael
> Sent: Friday, December 10, 2010 4:19 PM
> To: Andrew Johnson; [email protected]
> > From: Andrew Johnson [mailto:[email protected]]
> > > If there aren't major changes then next week I will create a
branch
> > with
> > > these changes and request a merge.
> > > The first stage will look like:
> > > > == Full list of renames
> > > > tools      = tools
> > > > libCom     = libCom
> > > > toolsComm  = libCom/tools
> > > > RTEMS      = libCom/RTEMS
> > > > as         = ioc/as
> > > > bpt        = ioc/bpt
> > > > db         = ioc/db
> > > > dbStatic   = ioc/dbStatic
> > > > dbtools    = ioc/dbtemplate
> > > > misc       = ioc/misc
> > > > registry   = ioc/registry
> > > > rsrv       = ioc/rsrv
> > > > dev/softDev= std/dev
> > > > dev/testDev= std/test
> > > > rec        = std/rec
> > > > softIoc    = std/softIoc
> > > > ca         = ca/client
> > > > cap5       = ca/client/perl
> > > > catools    = ca/client/tools
> > > > cas        = ca/legacy/pcas
> > > > excas      = ca/legacy/pcas/ex
> > > > gdd        = ca/legacy/gdd
> > > > makeBaseApp= template/base
> > > > makeBaseExt= template/ext
> > > > util       = util
> > One question about the layout: I'm wondering whether in the final
> > structure
> > individual directories should either be a branch node or a leaf
node,
> > i.e.
> > they should either contain sub-directories and a Makefile, or they
> > contain
> > source files and a Makefile, but never both.  Your ca/client and
> > ca/legacy/pcas directories are currently mixed nodes.
> Trying to adhere to this is what lead to present lib*Ioc situation.  I
> would rather start with what I want the result of the build to be, how
> I
> want the code to be organized, and then adapt the build system to
> produce it.
> > Was your intention to follow the libCom model for source
directories?
> Yes.  For the ioc/ and std/ directories at least.
> > My
> > worry is that the libCom/Makefile is unwieldy because it has to name
> > all of
> > the files in the different sub-directories.
> As long as the EPICS build system forces the distinction between
> branch/leaf node we will have this problem.
> The Makefiles will be large, but there will be fewer of them.
> Basically
> all of my dislike of the current build system come from the "evil"
> include statement, and having to hunt to find anything.  It may be a
> personal preference, but in the src/ directory at least I would rather
> have a few large Makefiles.
> Michael
RE: src/ reorganization Davidsaver, Michael
Re: src/ reorganization Andrew Johnson
Prev: Re: src/ reorganization Andrew Johnson
Next: RE: src/ reorganization Davidsaver, Michael
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: src/ reorganization Davidsaver, Michael
