> Did you see this?
Yes, but I was busy and didn?t respond - or admittedly take long
enough to consider the implications.
> and I suspect it will be necessary to build that before the
> IOC anyway.
Certainly rsrv does have dependencies on access security,
libCom, dbEvent.h, db_access.h, dbAccess.h - maybe others. So it
does appear that it get complicated if we don't initially place rsrv
where it can get built after its dependencies.
BTW, in the future this gets solved by placing only the cas db
service in the IOC subdirectory.
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: Davidsaver, Michael [mailto:[email protected]]
> Sent: Monday, December 20, 2010 10:22 AM
> To: Jeff Hill
> Subject: FW: src/ reorganization
> Hi Jeff,
> Did you see this?
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Andrew Johnson
> Sent: Friday, December 10, 2010 2:41 PM
> To: [email protected]
> Subject: Re: src/ reorganization
> On Friday 10 December 2010 13:13:47 Ben Franksen wrote:
> > On Freitag, 10. Dezember 2010, Davidsaver, Michael wrote:
> > > > rsrv = ioc/rsrv
> > This is the ca server, so I'd say the proper place is ca/server, not
> > ioc/rsrv.
> I disagree, with the current build dependencies that wouldn't make
> sense.
> Jeff will want to reserve the ca/server location for his new server, and
> I
> suspect it will be necessary to build that before the IOC anyway.
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it. If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence. -- Bertrand Russell
RE: src/ reorganization Jeff Hill
[Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base mdavidsaver
<2010>
2025
2026
RE: src/ reorganization (merge request) Davidsaver, Michael
<2010>
2025
2026
