2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: src/ reorganization
To: "'Davidsaver, Michael'" <[email protected]>, "'Andrew Johnson'" <[email protected]>, <[email protected]>
Date: Mon, 20 Dec 2010 09:31:46 -0700
Hi Michael,
I have been on vacation for a few days, setting tile in my basement.
I would still prefer for rsrv to be maintained in the ca subdirectory since
functionally it is part of channel access.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Davidsaver, Michael
> Sent: Friday, December 17, 2010 12:44 PM
> To: Andrew Johnson; [email protected]
> Step 2 is done:
> https://code.launchpad.net/~mdavidsaver/epics-base/reorg-src
> Should libCom/test/fdmgrTest be moved to ca/client/test/?  It is testing
> functionality in libCom, but uses parts of libca.  Currently it isn't
> (and wasn't) being built.
> Step 3 will merge libraries in libCom/ and ioc/.
> libCom will include asHost and rtemsCom.
> libdbCore will consist of dbStatic, db, registry, bpt, dbtemplate, rsrv,
> and misc
> libdbRecStd will consist of rec, dev, and softIoc
> The unit tests will remain in separate directories.
> Since there is agreement (or at least silence) on this I'm going to try
> to finish this today.  Given peoples schedules I assume the merge will
> wait until 2011.
> Regards,
> Michael
src/ reorganization Davidsaver, Michael
RE: src/ reorganization Davidsaver, Michael
Re: src/ reorganization Andrew Johnson
Prev: Re: src/ reorganization Andrew Johnson
Next: RE: src/ reorganization Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: src/ reorganization (merge request) Davidsaver, Michael
