2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS statistics on oholo.net
To: [email protected]
Date: Fri, 7 Jan 2011 13:13:29 -0600
On Friday 07 January 2011 12:48:24 I wrote:
> Ohloh is configured (under Development -> Enlistments if you're
> sufficiently privileged) to look for EPICS Base code in 3 separate Bazaar
> repositories, for 3.13, 3.14 and the old cvs-trunk (which is where Jeff has
> been working).  I've just added the new 3.15 repo to its list as well, but
> it won't download and include those stats until it gets to the front of its
> queue.  I'm guessing that it has just added up the totals from those 3
> repo's in reporting the counts.
I'm not as sure that I'm right about that now, there's a post on the Ohloh
forums that says they know their line counts are currently wrong.  I'm still
not sure how they handle multiple repo's, but it seems there may be other
issues causing this.  I've posted a forum question to ask them.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
EPICS statistics on oholo.net nick.rees
Re: EPICS statistics on oholo.net Andrew Johnson
Prev: Re: EPICS statistics on oholo.net Andrew Johnson
Next: Re: large arrays native element count wrong with Channel Access in EPICS 3.14.12 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
