2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: large arrays native element count wrong with Channel Access in EPICS 3.14.12
To: "Jeff Hill" <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Tue, 18 Jan 2011 11:08:27 -0600
Hi Jeff,
On Tuesday 18 January 2011 10:31:05 Jeff Hill wrote:
> PS: Andrew, FWIW and referencing the know problems page, it is actually
> possible to transfer large arrays w/o the patch. What doesn't work is
> communication of the native element count when the client connects.
Right, as long as your client library is 3.14.12 and you're using the dynamic
array sizing feature (which is still rare since it's a new feature).  However
I believe the client library clips all array get and subscription requests to
the array's native element count (or maybe it rejects them if too large, I
forget which), so I'm pretty sure that a client application using an older
library version against an unpatched 3.14.12 IOC isn't going to be able to
override the incorrect native count.  I haven't tried it though, so I might be
wrong.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
RE: large arrays native element count wrong with Channel Access in EPICS 3.14.12 Jeff Hill
Prev: Re: EPICS statistics on oholo.net Andrew Johnson
Next: RE: large arrays native element count wrong with Channel Access in EPICS 3.14.12 Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
