2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: src/ reorganization (merge request)
To: "Andrew Johnson" <[email protected]>
Cc: [email protected]
Date: Wed, 19 Jan 2011 17:53:58 -0500
Is there a schedule for reviewing this request?  Who all needs/wants to
review it?
> -----Original Message-----
> From: [email protected] [mailto:core-talk-
> [email protected]] On Behalf Of Davidsaver, Michael
> Sent: Monday, December 20, 2010 5:37 PM
> To: [email protected]
> > Sent: Friday, December 17, 2010 2:44 PM
> > To: Andrew Johnson; [email protected]
> > Since there is agreement (or at least silence) on this I'm going to
> try
> > to finish this today.  Given peoples schedules I assume the merge
> will
> > wait until 2011.
> Ok, that took longer than I expected, but it is ready now.  I tried
> building synApps 5.5 against it and the only problem I found was
> streamdevice having code with #ifdef EPICS_3_14.
> With this change Base build the following libraries:
> libca.so.3.15
> libcas.so.3.15
> libCom.so.3.15
> libdbCore.so.3.15
> libdbRecStd.so.3.15
> libdbStaticHost.so.3.15
> libgdd.so.3.15
> EPICS_BASE_IOC_LIBS = dbRecStd dbCore ca Com
> dbStaticHost will go away when Andrew's perl replacements are merged.
> I make a "fix" in src/libCom/tools/flex/parse.y which will probably
> need
> to be re-fixed.  There are now two 'main.c' files in CPP search path
> for
> libCom.  I wasn't sure if renaming would cause problems when merging
> future updates for flex.
> Also, what should be done with all the .rc file?  Do they need to be
> merged?
> dbCore_RCS = dbStaticIoc.rc registryIoc.rc dbIoc.rc asIoc.rc
> dbtoolsIoc.rc rsrvIoc.rc miscIoc.rc
> I've started a merge request so please direct comments/requests there.
> https://code.launchpad.net/~mdavidsaver/epics-base/reorg-
> src/+merge/4429
> 6
> Thanks,
> Michael
Prev: RE: large arrays native element count wrong with Channel Access in EPICS 3.14.12 Jeff Hill
Next: event ordering Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
