2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: class library header file naming and install conventions
To: "Jeff Hill" <[email protected]>
Cc: [email protected]
Date: Tue, 15 Mar 2011 11:58:43 -0600
On Tuesday 15 March 2011 12:38:52 Jeff Hill wrote:
> Yes, I am testing what you suggest since yesterday evening, and it works,
> but as Ralph and I were discussing its perhaps a bit awkward to not have
> the source files, and the header files, at the same level.
When you switch to Michael's new source layout the source and header files
*are* at the same level.  That works because the <something>/pdq/Makefile
fragment will contain the line
    SRC_DIRS += $(SOMETHING)/pdq
Thus the build system will use that path to find the .cpp files .h files while
compiling, but uses the original path to find the .h files when installing the
INC files.  Sorry I didn't write that earlier, but my subconscious was aware
of it.
Please look at Michael's branch like I asked before replying any further.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
class library header file naming and install conventions Jeff Hill
Re: class library header file naming and install conventions Andrew Johnson
RE: class library header file naming and install conventions Jeff Hill
Prev: RE: class library header file naming and install conventions Jeff Hill
Next: Re: os independent interface to socket sendmsg/recvmsg Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: class library header file naming and install conventions Andrew Johnson
