2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: os independent interface to socket sendmsg/recvmsg
To: [email protected]
Date: Tue, 15 Mar 2011 15:31:19 -0600
On Tuesday 15 March 2011 16:04:54 Eric Norum wrote:
> Once upon a time I had a look at building the libboost package (which I
> believe asio needs) for RTEMS. I ran aground trying to get the libboost and
> RTEMS build systems to play together. If you've had success with this it
> would be great to get it folded back into the RTEMS or libboost
> distribution.
I probably shouldn't have deleted this line from Michael's message:
On Tuesday 15 March 2011 09:42:22 Michael Davidsaver wrote:
> There is a boost-free version of ASIO.  This is actually what I used before.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
os independent interface to socket sendmsg/recvmsg Jeff Hill
Re: os independent interface to socket sendmsg/recvmsg Andrew Johnson
Re: os independent interface to socket sendmsg/recvmsg Eric Norum
Prev: Re: os independent interface to socket sendmsg/recvmsg Eric Norum
Next: Re: os independent interface to socket sendmsg/recvmsg Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
