2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: os independent interface to socket sendmsg/recvmsg
Cc: EPICS core-talk <[email protected]>
Date: Tue, 15 Mar 2011 17:50:55 -0400
On 3/15/2011 3:55 PM, Andrew Johnson wrote:
Looks interesting, have you tried building with it for RTEMS or vxWorks?
This was before I was working with EPICS so no.
I'm going to spend a little time and see if I can do something with the unit tests.
I probably shouldn't have deleted this line from Michael's message:
On Tuesday 15 March 2011 09:42:22 Michael Davidsaver wrote:
There is a boost-free version of ASIO.  This is actually what I used before.
Actually you should have since it is not correct ;) ASIO is less "boost-free" then I remember.
Re: os independent interface to socket sendmsg/recvmsg Eric Norum
ASIO and RTEMS Michael Davidsaver
os independent interface to socket sendmsg/recvmsg Jeff Hill
Re: os independent interface to socket sendmsg/recvmsg Andrew Johnson
Prev: Re: os independent interface to socket sendmsg/recvmsg Andrew Johnson
Next: Re: os independent interface to socket sendmsg/recvmsg Eric Norum
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
