2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: os independent interface to socket sendmsg/recvmsg
To: [email protected]
Cc: EPICS core-talk <[email protected]>
Date: Tue, 15 Mar 2011 15:03:53 -0700
"I felt a great disturbance -- as if thousands of small-memory IOCs cried out in terror and were then extinguished....."
On Mar 15, 2011, at 2:50 PM, Michael Davidsaver wrote:
> On 3/15/2011 3:55 PM, Andrew Johnson wrote:
>> Looks interesting, have you tried building with it for RTEMS or vxWorks?
> This was before I was working with EPICS so no.
> I'm going to spend a little time and see if I can do something with the unit tests.
>> I probably shouldn't have deleted this line from Michael's message:
>> On Tuesday 15 March 2011 09:42:22 Michael Davidsaver wrote:
>>> There is a boost-free version of ASIO.  This is actually what I used before.
> Actually you should have since it is not correct ;)  ASIO is less "boost-free" then I remember.
Eric Norum
[email protected]
os independent interface to socket sendmsg/recvmsg Jeff Hill
Re: os independent interface to socket sendmsg/recvmsg Andrew Johnson
Re: os independent interface to socket sendmsg/recvmsg Michael Davidsaver
Prev: Re: os independent interface to socket sendmsg/recvmsg Michael Davidsaver
Next: launchpad and proxied web access Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: ASIO and RTEMS Michael Davidsaver
