2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ASIO and RTEMS
To: [email protected]
Date: Wed, 16 Mar 2011 11:15:17 -0400
On 3/15/2011 5:50 PM, Michael Davidsaver wrote:
On 3/15/2011 3:55 PM, Andrew Johnson wrote:
Looks interesting, have you tried building with it for RTEMS or vxWorks?
This was before I was working with EPICS so no.
I'm going to spend a little time and see if I can do something with the unit tests.
I was able to run one unit test (the buffer test) on an mvme3100 w/ RTEMS 4.9. No source modification was required (yet).
I'm using the EPICS build system since that is the easiest way for me to build for RTEMS.
The ASIO unit tests are organized as a lot of separate executables. So my next step is to combine them into one as with the rtemsTestHarness. I'll post more when I see where this goes.
 Starting EPICS application *****
No iocsh -- netstat not registered
No iocsh -- heapSpace not registered
No iocsh -- nfsMount not registered
Running 1 test case...
*** No errors detected
***** IOC application terminating *****
Re: ASIO and RTEMS Michael Davidsaver
os independent interface to socket sendmsg/recvmsg Jeff Hill
Re: os independent interface to socket sendmsg/recvmsg Andrew Johnson
Re: os independent interface to socket sendmsg/recvmsg Michael Davidsaver
Prev: Re: launchpad and proxied web access Ralph Lange
Next: RE: class library header file naming and install conventions Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: os independent interface to socket sendmsg/recvmsg Eric Norum
Next: Re: ASIO and RTEMS Michael Davidsaver
