2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASIO and RTEMS
To: [email protected]
Date: Fri, 18 Mar 2011 17:34:38 -0400
On 3/16/2011 11:15 AM, Michael Davidsaver wrote:
On 3/15/2011 5:50 PM, Michael Davidsaver wrote:
On 3/15/2011 3:55 PM, Andrew Johnson wrote:
Looks interesting, have you tried building with it for RTEMS or vxWorks?
The ASIO unit tests are organized as a lot of separate executables. So my next step is to combine them into one as with the rtemsTestHarness. I'll post more when I see where this goes.
Getting ASIO to build, and combining the unit tests, was reasonably straight forward. The problem I've run into is that ASIO uses the newer name lookup functions like getnameinfo() instead of the (apparently) deprecated gethostbyname(). Unfortunately RTEMS doesn't implement them, so I'll have to find or write a wrapper.
Out of curiosity do any vxWorks versions implement: getnameinfo, getaddrinfo, freeaddrinfo, and gai_strerror?
Michael
Re: ASIO and RTEMS Andrew Johnson
os independent interface to socket sendmsg/recvmsg Jeff Hill
Re: os independent interface to socket sendmsg/recvmsg Andrew Johnson
Re: os independent interface to socket sendmsg/recvmsg Michael Davidsaver
ASIO and RTEMS Michael Davidsaver
Prev: [Bug 737632] Re: EPICS_TIMEZONE and osi*Time providers not documented Eric Norum
Next: Re: ASIO and RTEMS Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ASIO and RTEMS Michael Davidsaver
