On Friday 18 March 2011 16:34:38 Michael Davidsaver wrote:
> Getting ASIO to build, and combining the unit tests, was reasonably
> straight forward. The problem I've run into is that ASIO uses the newer
> name lookup functions like getnameinfo() instead of the (apparently)
> deprecated gethostbyname(). Unfortunately RTEMS doesn't implement them,
> so I'll have to find or write a wrapper.
> Out of curiosity do any vxWorks versions implement: getnameinfo,
> getaddrinfo, freeaddrinfo, and gai_strerror?
vxWorks 6 has those, vxWorks 5.5 does not.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
- os independent interface to socket sendmsg/recvmsg Jeff Hill
- ASIO and RTEMS Michael Davidsaver
- Re: ASIO and RTEMS Michael Davidsaver
Bug in epicsMessageQueue or unittest thereof Benjamin Franksen
<2011>
2025
2026
class library header file naming and install conventions Jeff Hill
<2011>
2025
2026
