2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 737632] Re: EPICS_TIMEZONE and osi*Time providers not documented
To: [email protected]
Date: Fri, 18 Mar 2011 18:16:26 -0000
On RTEMS the TZ environment variable can be used to set the time zone information and the dates at which to switch between standard and daylight-savings time.  The following example applies to Chicago for the daylight-savings times rules in effect for 2011:
	epicsEnvSet TZ "CST6CDT,M 3.2.0,M 11.1.0"
This sets the standard time name to CST and the daylight-savings time name to CDT.  Standard time is 6 hours behind GMT.  Daylight savings begins on the 0th day (Sunday) of the second week of the third month and ends on Sunday of the first week of the eleventh month.
The command
	epicsEnvSet TZ "CST6"
is applicable for Saskatchewan which stays on Central Standard Time all year.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Application Developers'
Guide.
https://bugs.launchpad.net/bugs/737632
Title:
Status in EPICS Application Developers' Guide:
  New
Bug description:
  There have been a number of changes to the environment parameters
  since section 7.8 was last revised.
  There needs to be documentation on the osiClockTime and osiNTPTime
  time providers, and the use of the EPICS_TIMEZONE parameter on
  vxWorks, and how this works on RTEMS.
[Bug 737632] [NEW] EPICS_TIMEZONE and osi*Time providers not documented Andrew Johnson
Prev: [Bug 737632] [NEW] EPICS_TIMEZONE and osi*Time providers not documented Andrew Johnson
Next: Re: ASIO and RTEMS Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: EPICS internals talks? nick.rees
