Subject: |
[Bug 737632] [NEW] EPICS_TIMEZONE and osi*Time providers not documented |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 18 Mar 2011 15:52:47 -0000 |
Public bug reported:
There have been a number of changes to the environment parameters since
section 7.8 was last revised.
There needs to be documentation on the osiClockTime and osiNTPTime time
providers, and the use of the EPICS_TIMEZONE parameter on vxWorks, and
how this works on RTEMS.
** Affects: epics-appdev
Importance: Undecided
Status: New
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Application Developers'
Guide.
https://bugs.launchpad.net/bugs/737632
Title:
Status in EPICS Application Developers' Guide:
New
Bug description:
since section 7.8 was last revised.
time providers, and the use of the EPICS_TIMEZONE parameter on
vxWorks, and how this works on RTEMS.
- [Bug 737632] [NEW] EPICS_TIMEZONE and osi*Time providers not documented Andrew Johnson
- [Bug 737632] Re: EPICS_TIMEZONE and osi*Time providers not documented Eric Norum
Re: [Merge] lp:~johill-lanl/epics-base/ca-ref-man-maint into lp:epics-base Ralph Lange
<2011>
2025
2026
RE: EPICS internals talks? nick.rees
<2011>
2025
2026
