Hi Michael,
On 2011-06-18 Michael Davidsaver wrote:
> > There were issues with using long long on some vxWorks
> > versions/architectures, although from what I can see they were only in
> > vxWorks 5.3.x releases and the later releases apparently do provide full
> > support. I believe there were some support routines that gcc calls
> > implicitly which the OS relegated to an external libgcc.a library rather
> > than building them into the OS image.
> Does sizeof(long)==8 in these cases? If it does then there is no need
> for long long.
Nope, 4 [when dealing with Wind River you need to be pessimistic, they've only
just started supporting SMP and LP64 in vxWorks 6.9 for some Intel x86_64
CPUs].
> My reason for not wanting to put these tests in libCom/test is that they
> are most useful when compiled before everything else. These checks are
> the sort usually found in autoconf ./configure scripts.
> I was tempted to put them into epicsTypes.h directly.
I see your point (fail fast), but I'm not sure that matters as much for us as
it does for other software [maybe it should and I'm thinking too small, but I
don't really see us speeding up porting such that we could use a ./configure
script without quite a lot of work]. I'd rather not have those checks in
epicsTypes.h given how much that file gets used compared with how often they
are expected to fail.
I do want to see the basic operations on 64-bit integers checked though, Ben's
experience shows that they aren't guaranteed, although I think vxWorks 5.5.x
does have the necessary routines included.
> > Are you looking for this in 3.14.x or 3.15?
> Certainly 3.15.
> I would also like to see it added to 3.14, if this can be done without
> breaking compatibility with old vxWorks versions. It is really up to
> you to decide if this can be done.
I think this really is 3.15 material.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- 64 bit integers (aka. long or long long) Michael Davidsaver
- Re: 64 bit integers (aka. long or long long) Andrew Johnson
- Re: 64 bit integers (aka. long or long long) Michael Davidsaver
Re: 64 bit integers (aka. long or long long) Benjamin Franksen
epicsThreadExitMain in softIoc program Benjamin Franksen
<2011>
2025
2026
<2011>
2025
2026
