2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: c++ static initialization
Cc: EPICS core-talk <[email protected]>
Date: Fri, 12 Aug 2011 01:10:42 +0200
Am Donnerstag, 11. August 2011, um 21:58:55 schrieb Andrew Johnson:
> On 2011-08-11 you wrote:
> >   if (!this->initialized) this->initialize();
> Your code above is not SMP-safe, and actually it's not even safe on a UP
> system in some circumstances.  If there are at least two threads running
> then they can both execute the initialize() method simultaneously (before
> the other thread sets the initialized member), which is obviously a Bad
> Thing™.  You can't even protect the initialize() routine with its own
> mutex because someone has to create the mutex for the routine to lock.
> The epicsThreadOnce() routine was designed to solve exactly this problem,
> and I believe we have already converted all the code in Base to use it.
> The result looks like this:
> static epicsThreadOnceId onceId = EPICS_THREAD_ONCE_INIT;
> static void once(void *junk)
> FILE * epicsShareAPI doSomething(...)
>     epicsThreadOnce(&onceId, once, 0);
Right. I confused epicsThreadOnce with thread local storage (such as, for
instance, used in the CA client API to store the current client context).
Sorry for the confusion.
I was actually aware of the problem; I took great care in the sequencer to
minimize the use of global variables and where I could not avoid them I
banished initialization (particularly: initialization of a global lock to
protect them) to the phase where the iocsh functions get registered (assuming
that no multitasking is active when this happens). Would this approach would
work for other subsystems?
> > > > (5) epicsThreadOnce should also be avoided wherever possible. Using
> > > > it
> > > >  means objects cannot be freely passed between threads which is
> > > > detriment to composability.
> > > But as Jeff implied, epicsThreadOnce() is essential to coding lazy
> > > initialization correctly on an SMP system.
> > I would like to see the argument that leads to such a conclusion.
> http://www.aristeia.com/Papers/DDJ_Jul_Aug_2004_revised.pdf
Thanks for the link. The paper confirms my opinion that singletons (static
objects, whatever) should be avoided whenever possible. They just cause
endless subtle problems.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
c++ static initialization Jeff Hill
Re: c++ static initialization Benjamin Franksen
Re: c++ static initialization Andrew Johnson
Prev: RE: c++ static initialization Jeff Hill
Next: c++ 0x initialization of local (block scoped) static variables Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: c++ static initialization Andrew Johnson
Next: RE: c++ static initialization Jeff Hill
