2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base
To: Jeff Hill <[email protected]>
Date: Thu, 18 Aug 2011 16:04:22 -0000
I like that compare+swap and void* operations are now implemented.
1) How about add and subtract?  For instructions sets which don't
support this directly it can be implemented in terms of compare+swap.*
So operations would be: Get, Set, Inc., Dec., Add, Subtract, and
Compare+Swap.  This is 7 functions.
For three types: unsigned int, size_t, and void*.  So a total of 21
functions.
2) I would suggest not making the locked functions part of the public
API.  I don't see one piece of code needing to use both
epicsLockedIncrSizeT and epicsAtomicIncrSizeT.  Perhaps instead have a
macro to force a fallback to the default implementation?
3) As a thought, how about signed instead of unsigned integers?  This
would differentiate 'int' from 'size_t' operations even on 32-bit machines.
* http://lists.debian.org/debian-68k/2008/09/msg00064.html
 From OpenJDK.  An implementation of atomic add for m68k (works on >= 68020)
http://68k.hax.com/CAS
https://code.launchpad.net/~epics-core/epics-base/epicsR3.15-atomics/+merge/70642
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base.
Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
Prev: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base mdavidsaver
Next: Re: [Merge] lp:~anj/epics-base/epicsEvent-api into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
Next: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
