2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base
Date: Thu, 25 Aug 2011 23:17:30 -0000
Review: Approve
A few minor things which I will correct while merging:
* This code uses C++ comments in C files (which GCC accepts, but some compilers don't).
* The test code uses status values which are not related to the code being tested as test pass/fail results.
* New release note entries go at the top of the file, not the bottom.
https://code.launchpad.net/~mshankar/epics-base/softioclogging/+merge/72816
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
[Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base Andrew Johnson
Prev: [Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base Andrew Johnson
Next: [Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base noreply
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
