2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base
To: [email protected]
Date: Thu, 25 Aug 2011 00:35:13 -0000
Andrew Johnson has proposed merging lp:~mshankar/epics-base/softioclogging into lp:epics-base.
Requested reviews:
  EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~mshankar/epics-base/softioclogging/+merge/72816
Codeathon: Add logClientPrefix command and functionality.
This branch includes code, tests and release notes.
AppDevGuide entry also supplied separately.
Your team EPICS Core Developers is requested to review the proposed merge of lp:~mshankar/epics-base/softioclogging into lp:epics-base.
=== modified file 'documentation/RELEASE_NOTES.html'
--- documentation/RELEASE_NOTES.html	2011-08-23 23:19:55 +0000
+++ documentation/RELEASE_NOTES.html	2011-08-25 00:35:04 +0000
@@ -280,5 +280,15 @@
 Removed the 3.13 &lt;top&gt;/config directory and build compatibility rules and
 variables, and various conversion documents.</p>
+<h3>
+Added support for iocLogPrefix</h3>
+<p>
+Added a <code>iocLogPrefix</code> command to <code>ioCsh</code>. This establishes a prefix that will be
+common to all log messages as they are sent to the iocLogServer. This lets us use the
+"fac=&lt;<i>facility</i>&gt;" syntax for displaying the facility, process name etc. in log viewers like the
+<code>cmlogviewer<code>.
+</p>
 </body>
 </html>
=== modified file 'src/libCom/iocsh/libComRegister.c'
--- src/libCom/iocsh/libComRegister.c	2010-05-03 22:26:41 +0000
+++ src/libCom/iocsh/libComRegister.c	2011-08-25 00:35:04 +0000
@@ -191,6 +191,15 @@
     errlogPrintfNoConsole("%s\n", args[0].sval);
+/* iocLogPrefix */
+static const iocshArg iocLogPrefixArg0 = { "prefix",iocshArgString};
+static const iocshArg * const iocLogPrefixArgs[1] = {&iocLogPrefixArg0};
+static const iocshFuncDef iocLogPrefixFuncDef = {"iocLogPrefix",1,iocLogPrefixArgs};
+static void iocLogPrefixCallFunc(const iocshArgBuf *args)
+    iocLogPrefix(args[0].sval);
 /* epicsThreadShowAll */
 static const iocshArg epicsThreadShowAllArg0 = { "level",iocshArgInt};
 static const iocshArg * const epicsThreadShowAllArgs[1] = {&epicsThreadShowAllArg0};
@@ -355,6 +364,7 @@
     iocshRegister(&errlogInitFuncDef,errlogInitCallFunc);
     iocshRegister(&errlogInit2FuncDef,errlogInit2CallFunc);
     iocshRegister(&errlogFuncDef, errlogCallFunc);
+    iocshRegister(&iocLogPrefixFuncDef, iocLogPrefixCallFunc);
     iocshRegister(&epicsThreadShowAllFuncDef,epicsThreadShowAllCallFunc);
     iocshRegister(&threadFuncDef, threadCallFunc);
=== modified file 'src/libCom/log/logClient.c'
--- src/libCom/log/logClient.c	2009-07-09 16:37:24 +0000
+++ src/libCom/log/logClient.c	2011-08-25 00:35:04 +0000
@@ -58,6 +58,11 @@
 static const double      LOG_SERVER_SHUTDOWN_TIMEOUT = 30.0; /* sec */
+ * The logClientPrefix stores a prefix that is sent as a prefix for all log messages.
+static char* logClientPrefix = NULL;
  * logClientClose ()
 static void logClientClose ( logClient *pClient )
@@ -160,21 +165,13 @@
- * logClientSend ()
+ * private method with code refactored out of logClientSend.
+ * This method relies on the mutex being obtained on pClient->mutex (which happens in logClientSend prior to this method being called)
-void epicsShareAPI logClientSend ( logClientId id, const char * message )
-    logClient * pClient = ( logClient * ) id;
+static void sendLogMessageinChunks(logClient * pClient, const char * message) {
     unsigned strSize;
-    if ( ! pClient || ! message ) {
-        return;
     strSize = strlen ( message );
-    epicsMutexMustLock ( pClient->mutex );
     while ( strSize ) {
         unsigned msgBufBytesLeft =
             sizeof ( pClient->msgBuf ) - pClient->nextMsgIndex;
@@ -231,10 +228,31 @@
             break;
+ * logClientSend ()
+void epicsShareAPI logClientSend ( logClientId id, const char * message )
+    logClient * pClient = ( logClient * ) id;
+    if ( ! pClient || ! message ) {
+        return;
+    epicsMutexMustLock ( pClient->mutex );
+    if(logClientPrefix) {
+        sendLogMessageinChunks(pClient, logClientPrefix);
+    sendLogMessageinChunks(pClient, message);
     epicsMutexUnlock (pClient->mutex);
 void epicsShareAPI logClientFlush ( logClientId id )
@@ -553,5 +571,33 @@
             pClient->sock==INVALID_SOCKET?"INVALID":"OK",
             pClient->connectCount);
+        printf ("log client: a log prefix has been set \"%s\"\n", logClientPrefix);
+ * iocLogPrefix()
+void epicsShareAPI iocLogPrefix(const char* prefix)
+    // If we have already established a log prefix, do not let the user change it
+    // Note iocLogPrefix is expected to be set in the cmd file during initialization.
+    // We do not anticipate changing this after it has been set
+        printf ("log client: a log prefix has already been established \"%s\". Ignoring this call \n", logClientPrefix);
+        return;
+    if(prefix) {
+        unsigned prefixLen = strlen(prefix);
+        if(prefixLen > 0) {
+            char* localCopy = malloc(prefixLen+1);
+            strcpy(localCopy, prefix);
+            logClientPrefix = localCopy;
=== modified file 'src/libCom/log/logClient.h'
--- src/libCom/log/logClient.h	2005-11-22 00:28:17 +0000
+++ src/libCom/log/logClient.h	2011-08-25 00:35:04 +0000
@@ -33,6 +33,7 @@
 epicsShareFunc void epicsShareAPI logClientSend (logClientId id, const char *message);
 epicsShareFunc void epicsShareAPI logClientShow (logClientId id, unsigned level);
 epicsShareFunc void epicsShareAPI logClientFlush (logClientId id);
+epicsShareFunc void epicsShareAPI iocLogPrefix(const char* prefix);
 /* deprecated interface; retained for backward compatibility */
 /* note: implementations are in iocLog.c, not logClient.c */
=== modified file 'src/libCom/test/epicsErrlogTest.c'
--- src/libCom/test/epicsErrlogTest.c	2011-03-01 21:03:33 +0000
+++ src/libCom/test/epicsErrlogTest.c	2011-08-25 00:35:04 +0000
@@ -22,6 +22,11 @@
 #include "errlog.h"
 #include "epicsUnitTest.h"
 #include "testMain.h"
+#include "iocLog.h"
+#include "logClient.h"
+#include "envDefs.h"
+#include "osiSock.h"
+#include "fdmgr.h"
 #define LOGBUFSIZE 2048
@@ -75,6 +80,27 @@
     int jam;
 } clientPvt;
+static void testLogPrefix(void);
+static void acceptNewClient( void *pParam );
+static void readFromClient( void *pParam );
+static void testPrefixLogandCompare( const char* logmessage);
+static void *pfdctx;
+static SOCKET sock;
+static SOCKET insock;
+static const char* prefixactualmsg[]= {
+                     "A message without prefix",
+                     "A message with prefix",
+                     "DONE"
+static const char prefixexpectedmsg[] =  "A message without prefix"
+                     "fac=LI21 A message with prefix"
+                     "fac=LI21 DONE"
+static char prefixmsgbuffer[1024];
 static
 void logClient(void* raw, const char* msg)
@@ -115,7 +141,7 @@
     char msg[256];
     clientPvt pvt, pvt2;
-    testPlan(25);
+    testPlan(35);
     strcpy(msg, truncmsg);
@@ -289,5 +315,143 @@
     /* Clean up */
     errlogRemoveListener(&logClient);
+    testLogPrefix();
     return testDone();
+ * Tests the log prefix code
+ * Since the log prefix is only applied to log messages as they are going out on the socket,
+ * we need to create a server listening on a port, accept connections etc.
+ * This code is a reduced version of the code in iocLogServer.
+static void testLogPrefix(void) {
+    struct sockaddr_in serverAddr;
+    int status;
+    struct timeval timeout;
+    struct sockaddr_in actualServerAddr;
+    osiSocklen_t actualServerAddrSize;
+    testDiag("Testing iocLogPrefix");
+    timeout.tv_sec = 5; /* in seconds */
+    timeout.tv_usec = 0;
+    memset((void*)prefixmsgbuffer, 0, sizeof prefixmsgbuffer);
+    /* Clear "errlog: <n> messages were discarded" status */
+    errlogPrintfNoConsole(".");
+    errlogFlush();
+    sock = epicsSocketCreate(AF_INET, SOCK_STREAM, 0);
+    testOk1(sock != INVALID_SOCKET);
+    // We listen on a an available port.
+    memset((void *)&serverAddr, 0, sizeof serverAddr);
+    serverAddr.sin_family = AF_INET;
+    serverAddr.sin_port = htons(0);
+    status = bind (sock,
+                   (struct sockaddr *)&serverAddr,
+                   sizeof (serverAddr) );
+    testOk1(status >= 0);
+    status = listen(sock, 10);
+    // Determine the port that the OS chose
+    actualServerAddrSize = sizeof actualServerAddr;
+    memset((void *)&actualServerAddr, 0, sizeof serverAddr);
+    status = getsockname(sock, (struct sockaddr *) &actualServerAddr, &actualServerAddrSize);
+    char portstring[16];
+    sprintf(portstring, "%d", ntohs(actualServerAddr.sin_port));
+    testDiag("Listening on port %s", portstring);
+    // Set the EPICS environment variables for logging.
+    epicsEnvSet ( "EPICS_IOC_LOG_INET", "localhost" );
+    epicsEnvSet ( "EPICS_IOC_LOG_PORT", portstring );
+    pfdctx = (void *) fdmgr_init();
+    testOk1(pfdctx != NULL);
+    status = fdmgr_add_callback(
+                  pfdctx,
+                  sock,
+                  fdi_read,
+                  acceptNewClient,
+                  &serverAddr);
+    status = iocLogInit ();
+    fdmgr_pend_event(pfdctx, &timeout);
+    testPrefixLogandCompare(prefixactualmsg[0]);
+    iocLogPrefix("fac=LI21 ");
+    testPrefixLogandCompare(prefixactualmsg[1]);
+    testPrefixLogandCompare(prefixactualmsg[2]);
+    close(sock);
+static void testPrefixLogandCompare( const char* logmessage ) {
+    errlogPrintfNoConsole(logmessage);
+    errlogFlush();
+    iocLogFlush();
+static void acceptNewClient ( void *pParam )
+    osiSocklen_t addrSize;
+    struct sockaddr_in addr;
+    int status;
+    addrSize = sizeof ( addr );
+    insock = epicsSocketAccept ( sock, (struct sockaddr *)&addr, &addrSize );
+    testOk1(insock!=INVALID_SOCKET && addrSize >= sizeof (addr) );
+                  pfdctx,
+                  insock,
+                  fdi_read,
+                  readFromClient,
+                  NULL);
+static void readFromClient(void *pParam)
+    char recvbuf[1024];
+    int recvLength;
+    memset(&recvbuf, 0, 1024);
+    recvLength = recv(insock,
+                      &recvbuf,
+                      1024,
+                      0);
+    if (recvLength > 0) {
+      strcat(prefixmsgbuffer, recvbuf);
+      // If we have received all of the messages.
+      if(strstr(prefixmsgbuffer, "DONE") != NULL) {
+          int prefixcmp = strncmp(prefixexpectedmsg, prefixmsgbuffer, strlen(prefixexpectedmsg));
+          if(prefixcmp != 0)  {
+             printf("Expected %s\n", prefixexpectedmsg);
+             printf("Obtained %s\n", prefixmsgbuffer);
+          testOk1(prefixcmp == 0);
Re: [Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base Andrew Johnson
[Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base noreply
Prev: Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base Andrew Johnson
Next: Re: [Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base noreply
