2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base
To: Jeff Hill <[email protected]>
Date: Sat, 27 Aug 2011 00:02:31 -0000
This doesn't fully cover all our architectures yet.
Both darwin and linux can build Base using clang, but when I use clang on Linux with the gcc header it doesn't hit the #error in compiler/gcc/compilerSpecific.h since clang defines __GNUC__ anyway.  There needs to be an easy way to make that switch (including setting CC and CCC) based on a single CONFIG_SITE setting.
Jeff: I'm happy to work on implementing these fixes back at ANL.  Have you based your atomic branch on this one?  I'd like to drop your 12229 merge commit, but that would probably mess you up if I did.
- Andrew
https://code.launchpad.net/~epics-core/epics-base/3.15-buildCompilerSpecific/+merge/72258
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base.
[Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base Jeff Hill
Prev: [Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base noreply
Next: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base Jeff Hill
Next: Re: [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base Jeff Hill
