Subject: |
[Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base |
Jeff Hill <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 19 Aug 2011 21:00:29 -0000 |
Jeff Hill has proposed merging lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base.
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~epics-core/epics-base/3.15-buildCompilerSpecific/+merge/72258
o Upgrade the build system so that we can implement functionality which is compiler specific in a separate file for each compiler. This will avoid accumulating MxN ifdef's where M is the number of OS and N is the number of compilers (worst case). This will make it easier to find code that is compiler specific centralizing all of it under libCom/osi/compiler. That should make it mush easier to port EPICS to run on a new compiler.
o I also re-factored compilerDependencies.h into code that is compiler specific (one libCom/osi/compiler/xxx/compilerDependent.h for each compiler) and code that isn't libCom/osi/compilerDependencies.h (this is a new location and is no longer in libCom/misc). I also merged recent change to R3.15 that prevents use of the gnu deprecated attribute if its early gcc.
Note that we don't want too much in each proposed merge. However, w/o a small code change such as the re-factoring of compilerDependencies.h then its somewhat problematic to test the build system change in the branch.
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base.
=== modified file 'configure/CONFIG.gnuCommon'
--- configure/CONFIG.gnuCommon 2009-11-25 17:15:47 +0000
+++ configure/CONFIG.gnuCommon 2011-08-19 21:00:26 +0000
@@ -12,6 +12,8 @@
GNU = YES
+CMPLR_CLASS = gcc
GNU_BIN = $(GNU_DIR)/bin
GNU_LIB = $(GNU_DIR)/lib
=== modified file 'configure/CONFIG_COMMON'
--- configure/CONFIG_COMMON 2011-08-17 21:36:38 +0000
+++ configure/CONFIG_COMMON 2011-08-19 21:00:26 +0000
@@ -133,11 +133,14 @@
GENERIC_SRC_DIRS = .. $(SRC_DIRS)
OS_SRC_DIRS += . $(foreach dir, .. $(SRC_DIRS), \
$(addprefix $(dir)/, os/$(OS_CLASS) $(POSIX_$(POSIX)) os/default ))
-ALL_SRC_DIRS = $(OS_SRC_DIRS) $(GENERIC_SRC_DIRS)
+CMPLR_SRC_DIRS += . $(foreach dir, .. $(SRC_DIRS), \
+ $(addprefix $(dir)/, compiler/$(CMPLR_CLASS) compiler/default ))
+ALL_SRC_DIRS = $(CMPLR_SRC_DIRS) $(OS_SRC_DIRS) $(GENERIC_SRC_DIRS)
# compile line include directories
INSTALL_INCLUDES += \
+ -I$(INSTALL_INCLUDE)/compiler/$(CMPLR_CLASS) \
-I$(INSTALL_INCLUDE)/os/$(OS_CLASS) \
SRC_INCLUDES = -I$(COMMON_DIR) $(addprefix -I, $(wildcard $(ALL_SRC_DIRS)))
@@ -379,25 +382,36 @@
# auto determine the directory paths that things are installed to
# RULES:
-# 1) found in any one of several os specific area
+# 0) found in any one of several compiler specific paths
+# => install to $(INSTALL_INCLUDE)/compiler/$(CMPLR_CLASS)
+# 1) not found in (0) and found in any one of several OS specific paths
# => install to $(INSTALL_INCLUDE)/os/$(OS_CLASS)
-# 2) not foundin (1) and found in generic area
+# 2) not found in (1) and found in generic paths
# 3) not found in (1) or (2) then may be (not yet) computer generated
# => install into $(INSTALL_INCLUDE)/os/$(OS_CLASS) and let
# build rules work on vpath
# These rules guarantee that the users include from
-# no more than two directories
+# no more than three directories
INSTALL_INC += $(foreach inc, $(INC), \
$(firstword \
+ $(CMPLR_INSTALL_INC) \
$(OS_INSTALL_INC) \
$(GENERIC_INSTALL_INC) \
$(GENERATED_INSTALL_INC) ) )
INSTALL_INC += $(addprefix $(INSTALL_INCLUDE)/os/$(OS_CLASS)/, $(INC_$(OS_CLASS)) )
+# Rule 0
+CMPLR_INSTALL_INC = $(addprefix $(INSTALL_INCLUDE)/compiler/$(CMPLR_CLASS)/, $(INSTALL_INC_jjj) )
+INSTALL_INC_jjj = $(foreach dir, $(CMPLR_SRC_DIRS), $(INSTALL_INC_iii) )
+INSTALL_INC_iii = $(subst $(dir)/, , $(INSTALL_INC_hhh) )
+INSTALL_INC_hhh = $(wildcard $(addsuffix /$(inc), $(dir)) )
# Rule 1
OS_INSTALL_INC = $(addprefix $(INSTALL_INCLUDE)/os/$(OS_CLASS)/, $(INSTALL_INC_ggg) )
=== modified file 'configure/RULES_BUILD'
--- configure/RULES_BUILD 2011-08-17 21:36:38 +0000
+++ configure/RULES_BUILD 2011-08-19 21:00:26 +0000
@@ -410,7 +410,11 @@
@$(INSTALL) -d -m $(INSTALL_PERMISSIONS) $< $(@D)
$(INSTALL_INCLUDE)/os/$(OS_CLASS)/% : %
- $(ECHO) "Installing os dependent include file $@"
+ $(ECHO) "Installing OS dependent include file $@"
+ @$(INSTALL) -d -m $(INSTALL_PERMISSIONS) $< $(@D)
+$(INSTALL_INCLUDE)/compiler/$(CMPLR_CLASS)/% : %
+ $(ECHO) "Installing compiler dependent include file $@"
$(INSTALL_DOC)/%: %
=== modified file 'configure/os/CONFIG.solarisCommon.solarisCommon'
--- configure/os/CONFIG.solarisCommon.solarisCommon 2010-10-05 19:27:37 +0000
+++ configure/os/CONFIG.solarisCommon.solarisCommon 2011-08-19 21:00:26 +0000
@@ -7,6 +7,8 @@
# Sites may override these definitions in CONFIG_SITE.solaris-sparc.solaris-sparc
+CMPLR_CLASS = solStudio
SPARCWORKS = /opt/SUNWspro
GNU = NO
=== modified file 'configure/os/CONFIG.win32-x86-borland.win32-x86-borland'
--- configure/os/CONFIG.win32-x86-borland.win32-x86-borland 2011-02-16 16:57:20 +0000
+++ configure/os/CONFIG.win32-x86-borland.win32-x86-borland 2011-08-19 21:00:26 +0000
@@ -7,6 +7,8 @@
# Sites may override these definitions in CONFIG_SITE.win32-x86-borland.win32-x86-borland
+CMPLR_CLASS = borland
# Win32 valid build types and include directory suffixes
VALID_BUILDS = Host Ioc
=== modified file 'configure/os/CONFIG.win32-x86.win32-x86'
--- configure/os/CONFIG.win32-x86.win32-x86 2011-08-17 21:36:38 +0000
+++ configure/os/CONFIG.win32-x86.win32-x86 2011-08-19 21:00:26 +0000
@@ -11,6 +11,8 @@
+CMPLR_CLASS = msvc
# convert UNIX path to native path
PATH_FILTER = $(subst /,\\,$(1))
=== modified file 'src/libCom/Makefile'
--- src/libCom/Makefile 2010-10-12 16:27:17 +0000
+++ src/libCom/Makefile 2011-08-19 21:00:26 +0000
@@ -136,7 +136,6 @@
INC += unixFileName.h
INC += locationException.h
INC += ipAddrToAsciiAsynchronous.h
-INC += compilerDependencies.h
INC += epicsUnitTest.h
INC += testMain.h
SRCS += aToIPAddr.c
@@ -195,6 +194,8 @@
INC += devLibVME.h
INC += devLibVMEImpl.h
INC += osdVME.h
+INC += compilerDependencies.h
+INC += compilerSpecific.h
SRCS += epicsThread.cpp
SRCS += epicsMutex.cpp
=== renamed file 'src/libCom/misc/compilerDependencies.h' => 'src/libCom/misc/compilerDependencies.h.THIS'
=== added directory 'src/libCom/osi/compiler'
=== added directory 'src/libCom/osi/compiler/borland'
=== added file 'src/libCom/osi/compiler/borland/compilerSpecific.h'
--- src/libCom/osi/compiler/borland/compilerSpecific.h 1970-01-01 00:00:00 +0000
+++ src/libCom/osi/compiler/borland/compilerSpecific.h 2011-08-19 21:00:26 +0000
@@ -0,0 +1,55 @@
+* Copyright (c) 2008 UChicago Argonne LLC, as Operator of Argonne
+* National Laboratory.
+* Copyright (c) 2002 The Regents of the University of California, as
+* Operator of Los Alamos National Laboratory.
+* EPICS BASE is distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
+ * Author:
+ * Jeffrey O. Hill
+ * [email protected]
+#ifndef compilerSpecific_h
+#define compilerSpecific_h
+#ifndef __BORLANDC__
+# error compiler/borland/compilerSpecific.h is only for use with the Borland compiler
+#endif
+#ifdef __cplusplus
+ * in general we dont like ifdefs but they do allow us to check the
+ * compiler version and make the optimistic assumption that
+ * standards incompliance issues will be fixed by future compiler
+ * releases
+ * CXX_PLACEMENT_DELETE - defined if compiler supports placement delete
+ * CXX_THROW_SPECIFICATION - defined if compiler supports throw specification
+#if __BORLANDC__ >= 0x600
+# define CXX_PLACEMENT_DELETE
+#endif
+#define CXX_THROW_SPECIFICATION
+#endif /* __cplusplus */
+ * Enable format-string checking if possible
+#define EPICS_PRINTF_STYLE(f,a)
+ * Deprecation marker
+#define EPICS_DEPRECATED
+#endif /* ifndef compilerSpecific_h */
=== added directory 'src/libCom/osi/compiler/clang'
=== added file 'src/libCom/osi/compiler/clang/compilerSpecific.h'
--- src/libCom/osi/compiler/clang/compilerSpecific.h 1970-01-01 00:00:00 +0000
+++ src/libCom/osi/compiler/clang/compilerSpecific.h 2011-08-19 21:00:26 +0000
@@ -0,0 +1,59 @@
+ * Author:
+ * Jeffrey O. Hill
+#ifndef __clang__
+# error compiler/clang/compilerSpecific.h is only for use with the clang compiler
+#endif
+ * WARNING: the current state of this file is only based on reading clang manuals
+ * and has not actually been tested with the compiler
+#pragma warning compiler/clang/compilerSpecific.h is based on reading the manual, but hasnt been tested with the clang compiler
+#ifdef __cplusplus
+#define CXX_PLACEMENT_DELETE
+#if __has_attribute(format)
+# define EPICS_PRINTF_STYLE(f,a) __attribute__((format(__printf__,f,a)))
+#else
+#endif
+ * Deprecation marker if possible
+#if __has_attribute(deprecated)
+# define EPICS_DEPRECATED __attribute__((deprecated))
+#else
+#endif
=== added directory 'src/libCom/osi/compiler/default'
=== added file 'src/libCom/osi/compiler/default/compilerSpecific.h'
--- src/libCom/osi/compiler/default/compilerSpecific.h 1970-01-01 00:00:00 +0000
+++ src/libCom/osi/compiler/default/compilerSpecific.h 2011-08-19 21:00:26 +0000
@@ -0,0 +1,45 @@
+ * Author:
+ * Jeffrey O. Hill
+#ifdef __cplusplus
+ * (our default guess is that the compiler implements the C++ 97 standard)
+ * (our default guess is that the compiler doesnt implement non-standard extensions)
=== added directory 'src/libCom/osi/compiler/gcc'
=== added file 'src/libCom/osi/compiler/gcc/compilerSpecific.h'
--- src/libCom/osi/compiler/gcc/compilerSpecific.h 1970-01-01 00:00:00 +0000
+++ src/libCom/osi/compiler/gcc/compilerSpecific.h 2011-08-19 21:00:26 +0000
@@ -0,0 +1,62 @@
+ * Author:
+ * Jeffrey O. Hill
+#ifndef __GNUC__
+# error compiler/gcc/compilerSpecific.h is only for use with the gnu compiler
+#endif
+#ifdef __cplusplus
+ * releases
+#if __GNUC__ > 2 || ( __GNUC__ == 2 && __GNUC_MINOR__ >= 95 )
+# define CXX_THROW_SPECIFICATION
+#endif
+#if __GNUC__ > 2 || ( __GNUC__ == 2 && __GNUC_MINOR__ >= 96 )
+#endif
+#define EPICS_PRINTF_STYLE(f,a) __attribute__((format(__printf__,f,a)))
+#if (__GNUC__ > 2)
+#else
+#endif
=== added directory 'src/libCom/osi/compiler/msvc'
=== added file 'src/libCom/osi/compiler/msvc/compilerSpecific.h'
--- src/libCom/osi/compiler/msvc/compilerSpecific.h 1970-01-01 00:00:00 +0000
+++ src/libCom/osi/compiler/msvc/compilerSpecific.h 2011-08-19 21:00:26 +0000
@@ -0,0 +1,57 @@
+ * Author:
+ * Jeffrey O. Hill
+#ifndef _MSC_VER
+# error compiler/msvc/compilerSpecific.h is only for use with the Microsoft compiler
+#endif
+#ifdef __cplusplus
+ * releases
+#if _MSC_VER >= 1200 /* visual studio 6.0 or later */
+#endif
+#if _MSC_VER > 1300 /* some release after visual studio 7 we hope */
+#endif
=== added directory 'src/libCom/osi/compiler/solStudio'
=== added file 'src/libCom/osi/compilerDependencies.h'
--- src/libCom/osi/compilerDependencies.h 1970-01-01 00:00:00 +0000
+++ src/libCom/osi/compilerDependencies.h 2011-08-19 21:00:26 +0000
@@ -0,0 +1,47 @@
+ * Author:
+ * Jeffrey O. Hill
+#ifndef compilerDependencies_h
+#define compilerDependencies_h
+#include "compilerSpecific.h"
+#ifdef __cplusplus
+ * usage: void func () epicsThrows (( std::bad_alloc, std::logic_error ))
+ * Note: now a widely accepted concensus (ref Meyers and C++ faq) is that
+ * one should avoid using throw specifications in C++ code
+#if defined ( CXX_THROW_SPECIFICATION )
+# define epicsThrows(X) throw X
+#else
+#endif
+ * usage: epicsPlacementDeleteOperator (( void *, myMemoryManager & ))
+#if defined ( CXX_PLACEMENT_DELETE )
+# define epicsPlacementDeleteOperator(X) void operator delete X;
+#else
+#endif
+#endif /* ifndef compilerDependencies_h */
- Re: [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base Andrew Johnson
- Re: [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base Jeff Hill
- [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base noreply
Re: [Merge] lp:~anj/epics-base/epicsEvent-api into lp:epics-base Andrew Johnson
Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
<2011>
2025
2026
c++ 0x initialization of local (block scoped) static variables Jeff Hill
<2011>
2025
2026
