2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: gcc 4.x symbol visibility
To: Jeff Hill <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Thu, 29 Sep 2011 16:46:49 -0500
Hi Jeff,
I came across this webpage some time ago http://gcc.gnu.org/wiki/Visibility
and added the relevant attributes to a private version of shareLib.h:
=== modified file 'src/libCom/misc/shareLib.h'
--- src/libCom/misc/shareLib.h  2008-08-06 16:52:52 +0000
+++ src/libCom/misc/shareLib.h  2011-09-28 22:38:37 +0000
@@ -139,6 +139,24 @@
 #   define epicsShareDef
 #   define epicsShareAPI __stdcall /* function removes arguments */
 #   define READONLY const
+#elif __GNUC__ >= 4
+ * See http://gcc.gnu.org/wiki/Visibility
+#   define epicsShareExtern __attribute__ ((visibility("default"))) extern
+#   define epicsShareClass __attribute__ ((visibility("default")))
+#   define epicsShareFunc __attribute__ ((visibility("default")))
+#   define epicsShareDef
+#   define epicsShareAPI
+#   if defined(__STDC__) || defined (__cplusplus)
+#       define READONLY const
+#   else
+#       define READONLY
+#   endif
  * if its the old VAX C Compiler (not DEC C)
When I enable it by adding the -fvisibility=hidden flag to gcc for a linux-
x86_64 build I get quite a reduction in teh number of exported symbols
(counted using 'nm -C -D | wc -l'):
Library               Original  Visibility
libca.so.3.15            1427         370
libcas.so.3.15           1167         336
libCom.so.3.15           1340         905
libdbCore.so.3.15         974         692
libdbRecStd.so.3.15       253         178
libdbStaticHost.so.3.15   232         208
libgdd.so.3.15            323         249
This looks like it would be a very worthwhile addition, except I'm getting a
couple of build errors for the 3.15 branch, can you work out what needs
decorating?
make[5]: Entering directory
`/home/phoebus3/ANJ/epics/base/mirror-3.15/src/ca/legacy/pcas/example/directoryService/O.linux-
x86_64'
/home/phoebus/ANJ/Linux64/bin/g++ -o caDirServ  -
L/home/phoebus3/ANJ/epics/base/mirror-3.15/lib/linux-x86_64 -Wl,-
rpath,/home/phoebus3/ANJ/epics/base/mirror-3.15/lib/linux-x86_64       -m64
main.o directoryServer.o   -lcas -lca -lgdd -lCom
directoryServer.o:(.rodata._ZTI15directoryServer[typeinfo for
directoryServer]+0x10): undefined reference to `typeinfo for caServer'
/home/phoebus3/ANJ/epics/base/mirror-3.15/lib/linux-x86_64/libcas.so:
undefined reference to `typeinfo for fdReg'
I'm also not sure where to set the -fvisibility flag, because it's not
supported before gcc 4.0 — I'll check with Janet, but ideas welcome...
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
RE: gcc 4.x symbol visibility Jeff Hill
Prev: [Merge] lp:~strauman/epics-base/stacktrace into lp:epics-base Till Straumann
Next: RE: gcc 4.x symbol visibility Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
