2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: "spinlock" API
To: EPICS core-talk <[email protected]>
Date: Thu, 07 Jun 2012 10:48:53 -0400
All,
For the implementation of thread pool I would like to allow it to be used from interrupt context on RTEMS/vxworks. So it should need to use epicsInterruptLock(). I want to avoid using a global lock on Linux/Windows/etc.
Now I could implement this internally for the thread pool only, but I thought I would float the possibility of creating a proper spin lock API. Initially RTEMS/vxworks would implement this using epicsInterrupt and the default implement would use epicsMutex.
Are there any supported OSs other than RTEMS/vxworks which allow a non-privileged thread/process to avoid being preempted?
This API might look like this.
struct epicsSL;
typedef struct epicsSL epicsSL;
typedef unsigned long epicsSLFlag;
#define epicsSLLocalFlag(name) epicsSLFlag name = 0
epicsSL* epicsSLCreate()
void epicsSLDestroy(epicsSL*);
void epicsSLLock(epicsSL*, epicsSLFlag*);
int epicsSLTryLock(epicsSL*, epicsSLFlag*);
void epicsSLUnlock(epicsSL*, epicsSLFlag*);
Usage would look like:
struct someStruct {
  epicsSL *SL;
myFunc(someStruct* X) {
  epicsSLLocalFlag(iflag);
  epicsSLLock(X->SL, &iflag);
  ... do stuff ...
  epicsSLUnlock(X->SL, &iflag);
@Andrew, The epicsSL names are just an example.
Michael
https://code.launchpad.net/~epics-core/epics-base/thread-pool/+merge/108385
Re: "spinlock" API Andrew Johnson
Prev: RE: epicsTimer and rounding Hill, Jeff
Next: Re: epicsTimer and rounding Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsTimer and rounding Dirk Zimoch
Next: Re: "spinlock" API Andrew Johnson
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
