Hi All,
I agree with Kay, that we have two different scenarios here and as a result we
need two different APIs. I also agree with Eric and Ralph that the basic
epicsThreadSleep() should follow the other implementations and *never* return
earlier than the requested time period. For example:
nanosleep() suspends the execution of the calling thread until either
at least the time specified in *req has elapsed, ...
The usleep() function suspends execution of the calling process for (at
least) usec microseconds. The sleep may be lengthened slightly by any
system activity or by the time spent processing the call or by the
granularity of system timers.
I have no problem with the idea of adding another routine that tries to
maintain a long-term processing period. However the scan threads do not use
epicsThreadSleep() for this anyway, they call epicsEventWaitWithTimeout()
because they need to be able to stop immediately when the IOC gets shut down,
so this API also needs to accept an epicsEventId and to be able to tell the
caller when it returns whether it's because of the timer or the event.
BTW, the CA client API should also provide a version of ca_pend_event() that
takes an epicsEventId for similar almost-immediate shutdown purposes.
- Andrew
On 2012-06-08 Kasemir, Kay wrote:
> I think Ralph's example of how 'sleep' is used is correct.
> Must sleep at least as long as requested.
> What Jeff describes is a periodic timer.
> The Java Timer class nicely offers both, allowing to
> a) schedule a task after some delay, with at least that delay
> b) schedule a periodic task, where the period between invocations might be
> 'squeezed' to achieve statistical correctness in the long run
> These are different scenarios, and one epicsThreadSleep() can't do both.
> The name epicsThreadSleep suggests to me that it's meant to be used for
> the 'sleep', not for scheduling a periodic task.
> That would require a different API like
> epicsThreadPeriodic(...)
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- RE: epicsTimer and rounding Hill, Jeff
- Re: epicsTimer and rounding Kasemir, Kay
<2012>
2025
2026
<2012>
2025
2026
