2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base
To: mdavidsaver <[email protected]>
Date: Fri, 15 Jun 2012 20:11:39 -0000
* Include in RTEMS/vxworks test harness
Done.
* For RTEMS/vxworks, replace mutex with interrupt disable
Done.
* Avoid excessive wakeups from worker and observer Events.
Done.
Also fixed several issues and added calls to shared thread pools.
Remaining task
Get approval of name epicsMaxParallelThreads()
https://code.launchpad.net/~epics-core/epics-base/thread-pool/+merge/108385
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/thread-pool into lp:epics-base.
[Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base mdavidsaver
Prev: Re: timer delay compensation Eric Norum
Next: Re: timer delay compensation Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base mdavidsaver
Next: Re: [Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base mdavidsaver
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
