I will not be working on the documentation change which was Ralph's first
issue, although if someone else writes the words I don't mind doing the
necessary edit and commit.
After spending longer than I should have on the second issue, I propose to
commit the following changes to the 3.14 branch, which I believe fixes all
reported issues with the epicsThreadSleep() implementations and makes them
robust against overflows and negative or NAN arguments.
=== modified file 'src/libCom/osi/os/RTEMS/osdThread.c'
--- src/libCom/osi/os/RTEMS/osdThread.c 2010-10-05 19:27:37 +0000
+++ src/libCom/osi/os/RTEMS/osdThread.c 2012-06-15 18:38:51 +0000
@@ -25,6 +25,7 @@
#include <stdio.h>
#include <assert.h>
#include <syslog.h>
+#include <limits.h>
#include <rtems.h>
#include <rtems/error.h>
@@ -364,17 +365,16 @@
rtems_status_code sc;
rtems_interval delay;
- extern double rtemsTicksPerTwoSeconds_double;
- if (seconds <= 0.0) {
+ extern double rtemsTicksPerSecond_double;
+ if (seconds > 0.0) {
+ seconds *= rtemsTicksPerSecond_double;
+ seconds += 0.99999999; /* 8 9s here is optimal */
+ delay = (seconds >= INT_MAX) ? INT_MAX : (int) seconds;
+ else { /* seconds <= 0 or NAN */
delay = 0;
- else {
- delay = seconds * rtemsTicksPerTwoSeconds_double;
- delay = (delay + 1) / 2;
- if (delay == 0)
- delay++;
sc = rtems_task_wake_after (delay);
if(sc != RTEMS_SUCCESSFUL)
errlogPrintf("epicsThreadSleep: %s\n", rtems_status_text (sc));
=== modified file 'src/libCom/osi/os/WIN32/osdThread.c'
--- src/libCom/osi/os/WIN32/osdThread.c 2012-02-03 00:14:01 +0000
+++ src/libCom/osi/os/WIN32/osdThread.c 2012-06-15 18:40:04 +0000
@@ -779,18 +779,15 @@
static const unsigned mSecPerSec = 1000;
DWORD milliSecDelay;
- if ( seconds <= 0.0 ) {
+ if ( seconds > 0.0 ) {
+ seconds *= mSecPerSec;
+ milliSecDelay = ( seconds >= INFINITE ) ?
+ INFINITE - 1 : ( DWORD ) seconds;
milliSecDelay = 0u;
- else if ( seconds >= INFINITE / mSecPerSec ) {
- milliSecDelay = INFINITE - 1;
- else {
- milliSecDelay = ( DWORD ) ( ( seconds * mSecPerSec ) + 0.5 );
- if ( milliSecDelay == 0 ) {
- milliSecDelay = 1;
Sleep ( milliSecDelay );
=== modified file 'src/libCom/osi/os/posix/osdThread.c'
--- src/libCom/osi/os/posix/osdThread.c 2012-02-03 00:14:01 +0000
+++ src/libCom/osi/os/posix/osdThread.c 2012-06-15 20:36:21 +0000
@@ -673,9 +673,15 @@
struct timespec remainingTime;
double nanoseconds;
- delayTime.tv_sec = (time_t)seconds;
- nanoseconds = (seconds - (double)delayTime.tv_sec) *1e9;
- delayTime.tv_nsec = (long)nanoseconds;
+ if (seconds > 0) {
+ delayTime.tv_sec = seconds;
+ nanoseconds = (seconds - delayTime.tv_sec) *1e9;
+ delayTime.tv_nsec = nanoseconds;
+ else {
+ delayTime.tv_sec = 0;
+ delayTime.tv_nsec = 0;
while (nanosleep(&delayTime, &remainingTime) == -1 &&
errno == EINTR)
delayTime = remainingTime;
=== modified file 'src/libCom/osi/os/vxWorks/osdThread.c'
--- src/libCom/osi/os/vxWorks/osdThread.c 2010-08-11 15:45:17 +0000
+++ src/libCom/osi/os/vxWorks/osdThread.c 2012-06-15 20:52:58 +0000
@@ -18,6 +18,7 @@
#include <stdlib.h>
#include <stddef.h>
#include <stdio.h>
#include <vxWorks.h>
#include <taskLib.h>
@@ -279,11 +280,13 @@
STATUS status;
int ticks;
- if(seconds<=0.0) {
+ seconds *= sysClkRateGet();
+ ticks = (seconds >= INT_MAX) ? INT_MAX : (int) seconds;
ticks = 0;
- } else {
- ticks = seconds*sysClkRateGet() + 0.5;
- if(ticks<=0) ticks = 1;
status = taskDelay(ticks);
if(status) errlogPrintf("epicsThreadSleep\n");
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- RE: timer delay compensation Hill, Jeff
- timer delay compensation Hill, Jeff
- Re: timer delay compensation Eric Norum
- Re: timer delay compensation Ralph Lange
Re: [Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base mdavidsaver
<2012>
2025
2026
Re: timer delay compensation Andrew Johnson
<2012>
2025
2026
