Hi Andrew,
No issues that I can see in your new windows version, which I have
maintained in the past, after a quick review.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Andrew Johnson
> Sent: Friday, June 15, 2012 3:03 PM
> To: [email protected]
> Subject: Re: timer delay compensation
> Hi,
> I will not be working on the documentation change which was Ralph's first
> issue, although if someone else writes the words I don't mind doing the
> necessary edit and commit.
> After spending longer than I should have on the second issue, I propose to
> commit the following changes to the 3.14 branch, which I believe fixes all
> reported issues with the epicsThreadSleep() implementations and makes them
> robust against overflows and negative or NAN arguments.
> === modified file 'src/libCom/osi/os/RTEMS/osdThread.c'
> --- src/libCom/osi/os/RTEMS/osdThread.c 2010-10-05 19:27:37 +0000
> +++ src/libCom/osi/os/RTEMS/osdThread.c 2012-06-15 18:38:51 +0000
> @@ -25,6 +25,7 @@
> #include <stdio.h>
> #include <assert.h>
> #include <syslog.h>
> +#include <limits.h>
> #include <rtems.h>
> #include <rtems/error.h>
> @@ -364,17 +365,16 @@
> rtems_status_code sc;
> rtems_interval delay;
> - extern double rtemsTicksPerTwoSeconds_double;
> - if (seconds <= 0.0) {
> + extern double rtemsTicksPerSecond_double;
> + if (seconds > 0.0) {
> + seconds *= rtemsTicksPerSecond_double;
> + seconds += 0.99999999; /* 8 9s here is optimal */
> + delay = (seconds >= INT_MAX) ? INT_MAX : (int) seconds;
> + else { /* seconds <= 0 or NAN */
> delay = 0;
> - else {
> - delay = seconds * rtemsTicksPerTwoSeconds_double;
> - delay = (delay + 1) / 2;
> - if (delay == 0)
> - delay++;
> sc = rtems_task_wake_after (delay);
> if(sc != RTEMS_SUCCESSFUL)
> errlogPrintf("epicsThreadSleep: %s\n", rtems_status_text (sc));
> === modified file 'src/libCom/osi/os/WIN32/osdThread.c'
> --- src/libCom/osi/os/WIN32/osdThread.c 2012-02-03 00:14:01 +0000
> +++ src/libCom/osi/os/WIN32/osdThread.c 2012-06-15 18:40:04 +0000
> @@ -779,18 +779,15 @@
> static const unsigned mSecPerSec = 1000;
> DWORD milliSecDelay;
> - if ( seconds <= 0.0 ) {
> + if ( seconds > 0.0 ) {
> + seconds *= mSecPerSec;
> + milliSecDelay = ( seconds >= INFINITE ) ?
> + INFINITE - 1 : ( DWORD ) seconds;
> milliSecDelay = 0u;
> - else if ( seconds >= INFINITE / mSecPerSec ) {
> - milliSecDelay = INFINITE - 1;
> - else {
> - milliSecDelay = ( DWORD ) ( ( seconds * mSecPerSec ) + 0.5 );
> - if ( milliSecDelay == 0 ) {
> - milliSecDelay = 1;
> Sleep ( milliSecDelay );
> === modified file 'src/libCom/osi/os/posix/osdThread.c'
> --- src/libCom/osi/os/posix/osdThread.c 2012-02-03 00:14:01 +0000
> +++ src/libCom/osi/os/posix/osdThread.c 2012-06-15 20:36:21 +0000
> @@ -673,9 +673,15 @@
> struct timespec remainingTime;
> double nanoseconds;
> - delayTime.tv_sec = (time_t)seconds;
> - nanoseconds = (seconds - (double)delayTime.tv_sec) *1e9;
> - delayTime.tv_nsec = (long)nanoseconds;
> + if (seconds > 0) {
> + delayTime.tv_sec = seconds;
> + nanoseconds = (seconds - delayTime.tv_sec) *1e9;
> + delayTime.tv_nsec = nanoseconds;
> + else {
> + delayTime.tv_sec = 0;
> + delayTime.tv_nsec = 0;
> while (nanosleep(&delayTime, &remainingTime) == -1 &&
> errno == EINTR)
> delayTime = remainingTime;
> === modified file 'src/libCom/osi/os/vxWorks/osdThread.c'
> --- src/libCom/osi/os/vxWorks/osdThread.c 2010-08-11 15:45:17 +0000
> +++ src/libCom/osi/os/vxWorks/osdThread.c 2012-06-15 20:52:58 +0000
> @@ -18,6 +18,7 @@
> #include <stdlib.h>
> #include <stddef.h>
> #include <stdio.h>
> #include <vxWorks.h>
> #include <taskLib.h>
> @@ -279,11 +280,13 @@
> STATUS status;
> int ticks;
> - if(seconds<=0.0) {
> + seconds *= sysClkRateGet();
> + ticks = (seconds >= INT_MAX) ? INT_MAX : (int) seconds;
> ticks = 0;
> - } else {
> - ticks = seconds*sysClkRateGet() + 0.5;
> - if(ticks<=0) ticks = 1;
> status = taskDelay(ticks);
> if(status) errlogPrintf("epicsThreadSleep\n");
> - Andrew
> Never interrupt your enemy when he is making a mistake.
> -- Napoleon Bonaparte
- timer delay compensation Hill, Jeff
- Re: timer delay compensation Eric Norum
- Re: timer delay compensation Ralph Lange
- Re: timer delay compensation Andrew Johnson
Re: [Merge] lp:~epics-core/epics-base/server-side-plugins into lp:epics-base Andrew Johnson
<2012>
2025
2026
<2012>
2025
2026
