Hi Eric,
On 2012-06-14 Eric Norum wrote:
> Well -- do all architectures provide float.h?
Yes, that's in ANSI C89 which everything supports.
> If so, then:
> void epicsThreadSleep(double seconds)
> STATUS status;
> int ticks;
> if (seconds <= 0.0) {
> ticks = 0;
> } else {
> ticks = (seconds * sysClkRateGet()) + (1.0 - DBL_EPSILON);
> status = taskDelay(ticks);
> if (status) errlogPrintf("epicsThreadSleep\n");
I thought that would work, but it adds an extra tick to longer delays. Sorry,
my bad for suggesting it. With sysClkRate = 60 it actually gives:
delay = 0.000 => ticks = 0
delay = 0.001 => ticks = 1
delay = 0.010 => ticks = 1
delay = 0.100 => ticks = 7
delay = 1.000 => ticks = 61
delay = 10.000 => ticks = 601
delay = 100.000 => ticks = 6001
> But I think that:
> STATUS status;
> int ticks;
> ticks = 0;
> } else {
> ticks = (seconds * sysClkRateGet()) + 0.999999;
> is just as good.
Lets go with 0.999999999, chosen since we only represent time down to the
nanosecond anyway.
Original algorithm
request = 0.000000000 => ticks = 0, error = 0.000000000
request = 0.000000001 => ticks = 1, error = 0.016666666
request = 0.000001000 => ticks = 1, error = 0.016665667
request = 0.001000000 => ticks = 1, error = 0.015666667
request = 0.010000000 => ticks = 1, error = 0.006666667
request = 0.016666667 => ticks = 1, error = 0.000000000
request = 0.020000000 => ticks = 1, error = -0.003333333
request = 0.030000000 => ticks = 2, error = 0.003333333
request = 0.033333333 => ticks = 2, error = 0.000000000
request = 0.040000000 => ticks = 2, error = -0.006666667
request = 0.050000000 => ticks = 3, error = 0.000000000
request = 0.060000000 => ticks = 4, error = 0.006666667
request = 0.070000000 => ticks = 4, error = -0.003333333
request = 0.080000000 => ticks = 5, error = 0.003333333
request = 0.090000000 => ticks = 5, error = -0.006666667
request = 0.100000000 => ticks = 6, error = 0.000000000
request = 0.166666667 => ticks = 10, error = 0.000000000
request = 0.200000000 => ticks = 12, error = 0.000000000
request = 0.300000000 => ticks = 18, error = 0.000000000
request = 0.333333333 => ticks = 20, error = 0.000000000
request = 0.500000000 => ticks = 30, error = 0.000000000
request = 0.666666667 => ticks = 40, error = 0.000000000
request = 0.750000000 => ticks = 45, error = 0.000000000
request = 1.000000000 => ticks = 60, error = 0.000000000
request = 5.000000000 => ticks = 300, error = 0.000000000
request = 10.000000000 => ticks = 600, error = 0.000000000
request = 60.000000000 => ticks = 3600, error = 0.000000000
request = 100.000000000 => ticks = 6000, error = 0.000000000
New algorithm
request = 0.020000000 => ticks = 2, error = 0.013333333
request = 0.040000000 => ticks = 3, error = 0.010000000
request = 0.070000000 => ticks = 5, error = 0.013333333
request = 0.090000000 => ticks = 6, error = 0.010000000
Negative errors are bad. However this only represents the error in the
requested delay, not the actual range of delays that could occur depending on
the time remaining until the next clock tick. I have no idea whether the OSs
try to compensate for that...
BTW, on vxWorks the taskDelay() routine only returns an error in interrupt
context or if the task gets an unblocked signal. Our code has a problem in
the first case because we call errlogPrintf(), and in the latter case we never
check errno or try to restart the delay on an EINTR. Luckily nobody uses
signals much on vxWorks...
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: timer delay compensation Eric Norum
- timer delay compensation Hill, Jeff
Re: timer delay compensation Andrew Johnson
<2012>
2025
2026
RE: timer delay compensation Hill, Jeff
<2012>
2025
2026
