Hi Steve,
On 2012-06-26 steve hunt wrote:
> perhaps the next release could have the caclient makebase app
> following this advice?
The code in the caClient template works just fine. It calls ca_get(), so the
subsequent ca_pend_io() won't return until the value has been received (or it
times out, causing the SEVCHK() to fail). You were the one who changed the
ca_get() call into ca_put(), which has different semantics as Jeff has
explained. Now I agree that adding an example which uses ca_put() might be a
good idea, but that's a different issue and doesn't represent a bug in the
current example code.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: pend_io Steve Hunt
- RE: pend_io Hill, Jeff
- Re: pend_io steve hunt
<2012>
2025
2026
<2012>
2025
2026
