2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: pend_io
To: steve hunt <[email protected]>
Date: Tue, 26 Jun 2012 18:23:04 +0000
> i dont remember this being necessary in the good old days :)
o Even in the good old days it was very OS dependent what
might happen if the ca client code exited w/o giving the
library a chance to close the sockets, and there was more
variability back then. As I recall the SSC even had the
record for the largest number of UNIX variations running :-)
o In the good old days we didn’t have opportunities for
multiple cores to work concurrently sending and receiving
messages to multiple sockets. This is a particularly important
point because, unlike in the past, we can now have N threads
all blocking for delivery in socket send concurrently. In the
past, inside of the ca_flush_io call, we had a for loop around
the N calls to socket send (which were enforced to complete
sequentially).
for the application to work concurrently at the same time
that the library is sending and receive messages to multiple
sockets.
for preemptive callback (from an auxiliary thread) to a
multithreaded application.
Jeff
> -----Original Message-----
> From: steve hunt [mailto:[email protected]]
> Sent: Tuesday, June 26, 2012 11:22 AM
> To: Hill, Jeff
> Cc: [email protected]
> Subject: Re: pend_io
> thanks Jeff,
> perhaps the next release could have the caclient makebase app
> following this advice?
> by the way, i dont remember this being necessary in the good old days :)
> cheers
> Steve
> Sent from my iPhone
> On 26 Jun 2012, at 19:12, "Hill, Jeff" <[email protected]> wrote:
> > Hi Steve,
> >> I changed caget to caput :)
> >> The value was not written to my ioc
> >> int main (int argc, char *argv[])
> >>        double  data=86;
> >>        chid        mychid;
> >>        SEVCHK(ca_create_channel(argv[1], NULL, NULL, 10,
> >>                          &mychid),"failure");
> >>        SEVCHK(ca_pend_io(10.0),"failure");
> >>        SEVCHK(ca_array_put(DBR_DOUBLE, 1, mychid, &data),"failure");
> > It's true that ca_pend_io causes an implicit flush to occur (i.e the
> > equivalent of a call to ca_flush_io).
> > A call to ca_flush_io is analogous to placing a letter in the mail
> > box.
> > We know now that the problem of delivery is out of our hands and has
> > been
> > entrusted to the postal service. So far so good, but the problem in
> > the above program is that a bomb has been dropped on our local postal
> > service before the letter can been delivered.
> > When your program exits from main without calling ca_context_destroy
> > then the ca client library's send threads are very ungracefully
> > terminated before they have been given a chance to deliver any
> > message that they might have in their work queues to TCP. Furthermore,
> > it is very OS dependent what might happen to any undelivered TCP
> > messages
> > lingering in the local IP kernel if you exit from main without given
> > the
> > CA client library an opportunity to close its TCP sockets; we end up
> > with undefined behavior.
> > In contrast, if the program calls ca_context_destroy before exiting
> > from main then the CA client library will gracefully shut down its
> > worker threads delivering all outstanding messages to the IP kernel
> > before they exit, and also gracefully close all of its sockets;
> > now we expect defined behavior.
> > There is a (very brief) discussion of this issue in the
> > troubleshooting
> > section of the CA reference manual - which perhaps could be expanded.
> > The bottom line is if you shouldn’t terminate the local postal servi
> > ce
> > unless you provide also some additional funding for a close out :-)
> > Jeff
> >> From: [email protected] [mailto:core-talk-
> >> [email protected]]
> >> On Behalf Of Steve Hunt
> >> Sent: Tuesday, June 26, 2012 7:49 AM
> >> To: [email protected]
> >> Subject: pend_io
> >> I have a problem running a trivial (too trivial it seems) ca client
> >> program.
> >> I fact I just generated the ca example using makeBaseApp.
> >> I am running 3.14.12.2, on linux_x86_64 but the behavior seems the
> >> same
> >> in older versions (at least 3.14.9(
> >> I am sending this to core-talk rather than tech-talk as this seems
> >> to be
> >> a real ca problem
> >> #######3
> >> #include <stddef.h>
> >> #include <stdlib.h>
> >> #include <stdio.h>
> >> #include <string.h>
> >> #include <cadef.h>
> >>        double  data=86;
> >>        chid        mychid;
> >> //      SEVCHK(ca_array_get(DBR_DOUBLE, 1, mychid, &data),"failure");
> >> //      SEVCHK(ca_pend_io(10.0),"failure");
> >> //      SEVCHK(ca_flush_io(),"failure");
> >> //      SEVCHK(ca_poll(),"failure");
> >> //      sleep(10);
> >> //      ca_context_destroy();
> >> //      return result;
> >> When I un-comment ca_poll, ca_context_destroy, ca_get (plus its
> >> pend_io), or sleep!!!  it works!!!
> >> so  a ca_poll, a ca_context_destroy, or a ca_pend_io AFTER a ca_get,
> >> seems to flush the send buffer - but just ca_pend_io, nor ca_flush_io
> >> seem not to do so.
> >> At least the client example generated from makebaseApp should have a
> >> ca_put added, and made to work without the ca_get, but perhaps this
> >> could be considered a bug.
RE: pend_io Hill, Jeff
pend_io Steve Hunt
Re: pend_io steve hunt
Prev: Re: pend_io Andrew Johnson
Next: RE: pend_io Hill, Jeff
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
