> Is there a short tutorial that you can add somewhere?
I should expand the paragraph on ca_context_destroy in the manual to
include some of this dialog.
Jeff
> -----Original Message-----
> From: Ernest L. Williams Jr. [mailto:[email protected]]
> Sent: Tuesday, June 26, 2012 11:20 AM
> To: Hill, Jeff
> Cc: EPICS core-talk
> Subject: Re: pend_io
> Hi Jeff,
> This thread helped me as well?
> Your analogy also made it very clear. :)
> Thanks,
> Ernest
> On 06/26/2012 10:12 AM, Hill, Jeff wrote:
> > Hi Steve,
> >> I changed caget to caput :)
> >> The value was not written to my ioc
> >> int main (int argc, char *argv[])
> >> double data=86;
> >> chid mychid;
> >> SEVCHK(ca_create_channel(argv[1], NULL, NULL, 10,
> >> &mychid),"failure");
> >> SEVCHK(ca_pend_io(10.0),"failure");
> >> SEVCHK(ca_array_put(DBR_DOUBLE, 1, mychid,&data),"failure");
> > It's true that ca_pend_io causes an implicit flush to occur (i.e the
> > equivalent of a call to ca_flush_io).
> > A call to ca_flush_io is analogous to placing a letter in the mail box.
> > We know now that the problem of delivery is out of our hands and has
> been
> > entrusted to the postal service. So far so good, but the problem in
> > the above program is that a bomb has been dropped on our local postal
> > service before the letter can been delivered.
> > When your program exits from main without calling ca_context_destroy
> > then the ca client library's send threads are very ungracefully
> > terminated before they have been given a chance to deliver any
> > message that they might have in their work queues to TCP. Furthermore,
> > it is very OS dependent what might happen to any undelivered TCP
> messages
> > lingering in the local IP kernel if you exit from main without given the
> > CA client library an opportunity to close its TCP sockets; we end up
> > with undefined behavior.
> > In contrast, if the program calls ca_context_destroy before exiting
> > from main then the CA client library will gracefully shut down its
> > worker threads delivering all outstanding messages to the IP kernel
> > before they exit, and also gracefully close all of its sockets;
> > now we expect defined behavior.
> > There is a (very brief) discussion of this issue in the troubleshooting
> > section of the CA reference manual - which perhaps could be expanded.
> > The bottom line is if you shouldn’t terminate the local postal service
> > unless you provide also some additional funding for a close out :-)
> > Jeff
> >> From: [email protected] [mailto:core-talk-
> [email protected]]
> >> On Behalf Of Steve Hunt
> >> Sent: Tuesday, June 26, 2012 7:49 AM
> >> To: [email protected]
> >> Subject: pend_io
> >> I have a problem running a trivial (too trivial it seems) ca client
> >> program.
> >> I fact I just generated the ca example using makeBaseApp.
> >> I am running 3.14.12.2, on linux_x86_64 but the behavior seems the same
> >> in older versions (at least 3.14.9(
> >> I am sending this to core-talk rather than tech-talk as this seems to
> be
> >> a real ca problem
> >> #######3
> >> #include<stddef.h>
> >> #include<stdlib.h>
> >> #include<stdio.h>
> >> #include<string.h>
> >> #include<cadef.h>
> >> double data=86;
> >> chid mychid;
> >> // SEVCHK(ca_array_get(DBR_DOUBLE, 1, mychid,&data),"failure");
> >> // SEVCHK(ca_pend_io(10.0),"failure");
> >> // SEVCHK(ca_flush_io(),"failure");
> >> // SEVCHK(ca_poll(),"failure");
> >> // sleep(10);
> >> // ca_context_destroy();
> >> // return result;
> >> When I un-comment ca_poll, ca_context_destroy, ca_get (plus its
> >> pend_io), or sleep!!! it works!!!
> >> so a ca_poll, a ca_context_destroy, or a ca_pend_io AFTER a ca_get,
> >> seems to flush the send buffer - but just ca_pend_io, nor ca_flush_io
> >> seem not to do so.
> >> At least the client example generated from makebaseApp should have a
> >> ca_put added, and made to work without the ca_get, but perhaps this
> >> could be considered a bug.
- pend_io Steve Hunt
- RE: pend_io Hill, Jeff
- Re: pend_io Ernest L. Williams Jr.
<2012>
2025
2026
Re: pend_io steve hunt
<2012>
2025
2026
