2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RFC: libCom/osi - new spinlock API
To: [email protected]
Date: Thu, 18 Oct 2012 10:39:21 -0500
Hi Ralph,
On 2012-10-18 Ralph Lange wrote:
> > BTW, if pthread_spin_lock() is not implemented, using a native
> > pthread_mutex_t might be lighter weight than an epicsMutex object.
> On Posix, yes. (Only slightly though, as the Posix implementation of
> epicsMutex uses pthread_mutex_t.)
The *second* implementation in osi/posix/osdMutex.c (for Posix OSs where
PTHREAD_MUTEX_RECURSIVE is  not available) is where it will make more of a
difference, and that is more likely to be used where pthread_spin_lock() is
not available.  Not as important though I agree.
> The Default should be epicsMutex, to make things work on Windows etc.
> until specific implementations are in place.
At the moment most target builds (other than self-hosted Windows) search the
os/posix source directories for files before os/default, so you can't rely on
the os/default implementation being used if there is an os/posix one.  This is
a bit stupid, but I haven't tried setting POSIX=NO in the vxWorks or RTEMS
target configuration files so I don't know how hard that might be to change.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: RFC: libCom/osi - new spinlock API Ralph Lange
Re: RFC: libCom/osi - new spinlock API Andrew Johnson
Prev: Re: RFC: libCom/osi - new spinlock API Ralph Lange
Next: Re: RFC: libCom/osi - new spinlock API Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
