Hi Nick,
On 2012-10-24 [email protected] wrote:
> I don't know the details, but I suspect this will impact the large number
> of sites (like Diamond) that have not upgraded to VxWorks 6. This may be
> because when EPICS moved to 3.14 and the IOC became portable, a lot of us
> decided that our futures lay elsewhere.
This is not related to vxWorks at all; we will continue to support vxWorks
5.5.x for as long as possible, but this question relates only to systems using
the Posix OSD routines in libCom. Our vxWorks OSD routines do not use those
Posix routines.
Ralph asked:
> to get access to the Posix spinlocks, one must set
> -D_POSIX_C_SOURCE=200112L (or greater).
> Currently, base uses -D_POSIX_C_SOURCE=199506L.
> Should we change this globally? Would this break anything?
I suspect not, have you tried it on Linux? Assuming that does what you need
I'd say go ahead and we can test the result to ensure it doesn't break other
architectures later.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: RFC: libCom/osi - new spinlock API Ralph Lange
- RFC: libCom/osi - new spinlock API Ralph Lange
- RE: RFC: libCom/osi - new spinlock API nick.rees
<2012>
2025
2026
<2012>
2025
2026
