2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RFC: libCom/osi - new spinlock API
To: EPICS Core Talk <[email protected]>
Date: Mon, 29 Oct 2012 22:10:01 +0100
I have pushed my spinlocks branch onto Launchpad at
https://code.launchpad.net/~epics-core/epics-base/spinlocks
This has two variants of posix implementations (pthread_spin if
available, else pthread_mutex), one for vxWorks/single CPU (intLock),
and a default implementation (epicsMutex).
I added test code (based on the tests for epicsMutex), and tested both
posix variants and the default implementation on my Linux box.
On this machine, I found the posix spinlock implementation working about
twice as fast as the posix mutex.
Please test and verify on other platforms
(RTEMS/vxWorks/Windows/Solaris/OSX) if you have a chance.
Thanks a lot!
~Ralph
Re: RFC: libCom/osi - new spinlock API Andrew Johnson
RFC: libCom/osi - new spinlock API Ralph Lange
Re: RFC: libCom/osi - new spinlock API Ralph Lange
RE: RFC: libCom/osi - new spinlock API nick.rees
Prev: Re: RFC: libCom/osi - new spinlock API Andrew Johnson
Next: [Merge] lp:~epics-core/epics-base/spinlocks into lp:epics-base Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: RFC: libCom/osi - new spinlock API Andrew Johnson
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
