Hi Michael,
On Jan 22, 2013, at 6:19 PM, Michael Davidsaver <[email protected]> wrote:
> I've posted another iteration. The changes have actually gotten much shorter.
> The first patch changes dbAccess.c and arr.c to save the original value of DBADDR::pfield before calling get_array_info, then restore it immediately after.
> http://bazaar.launchpad.net/~epics-core/epics-base/array-opt/revision/12397
I haven't tried this, but it looks much better.
> The second patch changes waveformRecord.c to allow the safe replacement of BPTR whenever the record is locked. No special allocation, or pointer tricks, are needed.
> http://bazaar.launchpad.net/~epics-core/epics-base/array-opt/revision/12398
You can simplify it even more; use &prec->val instead of &prec->bptr as the field identifier to db_post_event() because cvt_dbaddr() doesn't need to change the paddr->pfield value at all then, it's already pointing to the val field on entry.
Is this completely backwards compatible with existing waveform device support? I get the impression that it should be, but I haven't checked. If so even the waveform record changes would be acceptable to merge into 3.15. I would like some documentation on how to do double-buffering in device support though.
BTW, have you looked at the aai record type in 3.15 at all? I'm not saying it would necessarily be better than the waveform for your needs, but it is similar but with slightly different buffer semantics. Would it be sensible to make similar changes to this?
- Andrew
- Re: double buffered waveformRecord Michael Davidsaver
- double buffered waveformRecord Michael Davidsaver
- Re: double buffered waveformRecord Andrew Johnson
- Re: double buffered waveformRecord Ralph Lange
<2013>
2025
2026
<2013>
2025
2026
