2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] lp:~epics-core/epics-base/devlib2mmio into lp:epics-base
To: [email protected]
Date: Fri, 10 May 2013 20:33:26 -0000
mdavidsaver has proposed merging lp:~epics-core/epics-base/devlib2mmio into lp:epics-base.
Requested reviews:
  EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~epics-core/epics-base/devlib2mmio/+merge/163365
>From devLib2
adds calls to handle 8, 16, and 32 bit
Memory Mapped I/O reads and writes.
Adds X_iowriteY() and X_ioreadY().
where X is nat (native), be, or le.
Y is 16 or 32.
Also adds ioread8() and iowrite8().
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/devlib2mmio into lp:epics-base.
=== modified file 'src/libCom/osi/Makefile'
--- src/libCom/osi/Makefile	2012-10-29 19:25:23 +0000
+++ src/libCom/osi/Makefile	2013-05-10 20:32:35 +0000
@@ -61,6 +61,8 @@
 INC += devLibVME.h
 INC += devLibVMEImpl.h
 INC += osdVME.h
+INC += epicsMMIO.h
+INC += epicsMMIODef.h
 Com_SRCS += epicsThread.cpp
 Com_SRCS += epicsMutex.cpp
=== added file 'src/libCom/osi/os/RTEMS/epicsMMIO.h'
--- src/libCom/osi/os/RTEMS/epicsMMIO.h	1970-01-01 00:00:00 +0000
+++ src/libCom/osi/os/RTEMS/epicsMMIO.h	2013-05-10 20:32:35 +0000
@@ -0,0 +1,58 @@
+* Copyright (c) 2010 Brookhaven Science Associates, as Operator of
+*     Brookhaven National Laboratory.
+* devLib2 is distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
+ * Author: Michael Davidsaver <[email protected]>
+#ifndef EPICSMMIO_H
+#define EPICSMMIO_H
+#include <epicsEndian.h>
+#if defined(_ARCH_PPC) || defined(__PPC__) || defined(__PPC)
+#  include <libcpu/io.h>
+/*NOTE: All READ/WRITE operations have an implicit read or write barrier */
+#  define ioread8(A)         in_8((volatile epicsUInt8*)(A))
+#  define iowrite8(A,D)      out_8((volatile epicsUInt8*)(A), D)
+#  define le_ioread16(A)     in_le16((volatile epicsUInt16*)(A))
+#  define le_ioread32(A)     in_le32((volatile epicsUInt32*)(A))
+#  define le_iowrite16(A,D)  out_le16((volatile epicsUInt16*)(A), D)
+#  define le_iowrite32(A,D)  out_le32((volatile epicsUInt32*)(A), D)
+#  define be_ioread16(A)     in_be16((volatile epicsUInt16*)(A))
+#  define be_ioread32(A)     in_be32((volatile epicsUInt32*)(A))
+#  define be_iowrite16(A,D)  out_be16((volatile epicsUInt16*)(A), D)
+#  define be_iowrite32(A,D)  out_be32((volatile epicsUInt32*)(A), D)
+#  define rbarr()  iobarrier_r()
+#  define wbarr()  iobarrier_w()
+#  define rwbarr() iobarrier_rw()
+/* Define native operations */
+#  define nat_ioread16  be_ioread16
+#  define nat_ioread32  be_ioread32
+#  define nat_iowrite16 be_iowrite16
+#  define nat_iowrite32 be_iowrite32
+#elif defined(i386) ||defined(__i386__) || defined(__i386)
+/* X86 does not need special handling for read/write width.
+ * TODO: Memory barriers?
+#include "epicsMMIODef.h"
+#else
+#  warning I/O operations not defined for this RTEMS architecture
+#endif /* if defined PPC */
+#endif /* EPICSMMIO_H */
=== added file 'src/libCom/osi/os/default/epicsMMIO.h'
--- src/libCom/osi/os/default/epicsMMIO.h	1970-01-01 00:00:00 +0000
+++ src/libCom/osi/os/default/epicsMMIO.h	2013-05-10 20:32:35 +0000
@@ -0,0 +1,2 @@
=== added file 'src/libCom/osi/os/default/epicsMMIODef.h'
--- src/libCom/osi/os/default/epicsMMIODef.h	1970-01-01 00:00:00 +0000
+++ src/libCom/osi/os/default/epicsMMIODef.h	2013-05-10 20:32:35 +0000
@@ -0,0 +1,268 @@
+#ifndef EPICSMMIODEF_H
+#define EPICSMMIODEF_H
+#include <epicsTypes.h>
+#include <shareLib.h>
+#ifdef __cplusplus
+#  ifndef INLINE
+#    define INLINE inline
+#  endif
+#endif
+/** @ingroup mmio
+/** @brief Read a single byte.
+INLINE
+epicsUInt8
+ioread8(volatile void* addr)
+    return *(volatile epicsUInt8*)(addr);
+/** @brief Write a single byte.
+INLINE
+void
+iowrite8(volatile void* addr, epicsUInt8 val)
+    *(volatile epicsUInt8*)(addr) = val;
+/** @brief Read two bytes in host order.
+ * Not byte swapping
+INLINE
+epicsUInt16
+nat_ioread16(volatile void* addr)
+    return *(volatile epicsUInt16*)(addr);
+/** @brief Write two byte in host order.
+INLINE
+void
+nat_iowrite16(volatile void* addr, epicsUInt16 val)
+    *(volatile epicsUInt16*)(addr) = val;
+/** @brief Read four bytes in host order.
+INLINE
+epicsUInt32
+nat_ioread32(volatile void* addr)
+    return *(volatile epicsUInt32*)(addr);
+/** @brief Write four byte in host order.
+INLINE
+void
+nat_iowrite32(volatile void* addr, epicsUInt32 val)
+    *(volatile epicsUInt32*)(addr) = val;
+#if EPICS_BYTE_ORDER == EPICS_ENDIAN_BIG
+/** @ingroup mmio
+#define bswap16(value) ((epicsUInt16) (  \
+        (((epicsUInt16)(value) & 0x00ff) << 8)    |       \
+        (((epicsUInt16)(value) & 0xff00) >> 8)))
+#define bswap32(value) (  \
+        (((epicsUInt32)(value) & 0x000000ff) << 24)   |                \
+        (((epicsUInt32)(value) & 0x0000ff00) << 8)    |                \
+        (((epicsUInt32)(value) & 0x00ff0000) >> 8)    |                \
+        (((epicsUInt32)(value) & 0xff000000) >> 24))
+#  define be_ioread16(A)    nat_ioread16(A)
+#  define be_ioread32(A)    nat_ioread32(A)
+#  define be_iowrite16(A,D) nat_iowrite16(A,D)
+#  define be_iowrite32(A,D) nat_iowrite32(A,D)
+#  define le_ioread16(A)    bswap16(nat_ioread16(A))
+#  define le_ioread32(A)    bswap32(nat_ioread32(A))
+#  define le_iowrite16(A,D) nat_iowrite16(A,bswap16(D))
+#  define le_iowrite32(A,D) nat_iowrite32(A,bswap32(D))
+#elif EPICS_BYTE_ORDER == EPICS_ENDIAN_LITTLE
+#include <arpa/inet.h>
+#ifdef __rtems__
+   /* some rtems bsps (pc386) don't provide htonl correctly */
+#  include <rtems/endian.h>
+#endif
+/** @ingroup mmio
+/* hton* is optimized or a builtin for most compilers
+ * so use it if possible
+#define bswap16(v) htons(v)
+#define bswap32(v) htonl(v)
+#  define be_ioread16(A)    bswap16(nat_ioread16(A))
+#  define be_ioread32(A)    bswap32(nat_ioread32(A))
+#  define be_iowrite16(A,D) nat_iowrite16(A,bswap16(D))
+#  define be_iowrite32(A,D) nat_iowrite32(A,bswap32(D))
+#  define le_ioread16(A)    nat_ioread16(A)
+#  define le_ioread32(A)    nat_ioread32(A)
+#  define le_iowrite16(A,D) nat_iowrite16(A,D)
+#  define le_iowrite32(A,D) nat_iowrite32(A,D)
+#else
+#  error Unable to determine native byte order
+#endif
+/** @def bswap16
+ *  @brief Unconditional two byte swap
+/** @def bswap32
+ *  @brief Unconditional four byte swap
+/** @def be_ioread16
+ *  @brief Read two byte in big endian order.
+/** @def be_iowrite16
+ *  @brief Write two byte in big endian order.
+/** @def be_ioread32
+ *  @brief Read four byte in big endian order.
+/** @def be_iowrite32
+ *  @brief Write four byte in big endian order.
+/** @def le_ioread16
+ *  @brief Read two byte in little endian order.
+/** @def le_iowrite16
+ *  @brief Write two byte in little endian order.
+/** @def le_ioread32
+ *  @brief Read four byte in little endian order.
+/** @def le_iowrite32
+ *  @brief Write four byte in little endian order.
+/** @ingroup mmio
+/** @brief Explicit read memory barrier
+ * Prevents reordering of reads around it.
+#define rbarr()  do{}while(0)
+/** @brief Explicit write memory barrier
+ * Prevents reordering of writes around it.
+#define wbarr()  do{}while(0)
+/** @brief Explicit read/write memory barrier
+ * Prevents reordering of reads or writes around it.
+#define rwbarr() do{}while(0)
+/** @defgroup mmio Memory Mapped I/O
+ * Safe operations on I/O memory.
+ *This files defines a set of macros for access to Memory Mapped I/O
+ *They are named T_ioread# and T_iowrite# where # can be 8, 16, or 32.
+ *'T' can either be 'le', 'be', or 'nat' (except ioread8 and
+ *iowrite8).
+ *The macros defined use OS specific extensions (when available)
+ *to ensure the following.
+ *@li Width.  A 16 bit operation will not be broken into two 8 bit operations,
+ *           or one half of a 32 bit operation.
+ *@li Order.  Writes to two different registers will not be reordered.
+ *           This only applies to MMIO operations, not between MMIO and
+ *           normal memory operations.
+ *PCI access should use either 'le_' or 'be_' as determined by the
+ *device byte order.
+ *VME access should always use 'nat_'.  If the device byte order is
+ *little endian then an explicit swap is required.
+ *@section mmioex Examples:
+ *@subsection mmioexbe Big endian device:
+ *@b PCI
+ @code
+  be_iowrite16(base+off, 14);
+  var = be_ioread16(base+off);
+ @endcode
+ *@b VME
+ @code
+  nat_iowrite16(base+off, 14);
+  var = nat_ioread16(base+off);
+ @endcode
+ *@subsection mmioexle Little endian device
+ *@b PCI
+ @code
+  le_iowrite16(base+off, 14);
+  var = le_ioread16(base+off);
+ @endcode
+ *@b VME
+ @code
+  nat_iowrite16(base+off, bswap16(14));
+  var = bswap16(nat_iowrite16(base+off));
+ @endcode
+ *This difference arises because VME bridges implement hardware byte
+ *swapping on little endian systems, while PCI bridges do not.
+ *Software accessing PCI devices must know if byte swapping is required.
+ *This conditional swap is implemented by the 'be_' and 'le_' macros.
+ *This is a fundamental difference between PCI and VME.
+ *Software accessing PCI @b must do conditional swapping.
+ *Software accessing VME must @b not do conditional swapping.
+ *@note All read and write operations have an implicit read or write barrier.
+#endif /* EPICSMMIODEF_H */
=== added file 'src/libCom/osi/os/vxWorks/epicsMMIO.h'
--- src/libCom/osi/os/vxWorks/epicsMMIO.h	1970-01-01 00:00:00 +0000
+++ src/libCom/osi/os/vxWorks/epicsMMIO.h	2013-05-10 20:32:35 +0000
@@ -0,0 +1,127 @@
+* Copyright (c) 2006 The University of Chicago,
+*     as Operator of Argonne National Laboratory.
+* Copyright (c) 2006 The Regents of the University of California,
+*     as Operator of Los Alamos National Laboratory.
+* Copyright (c) 2006 The Board of Trustees of the Leland Stanford Junior
+*     University, as Operator of the Stanford Linear Accelerator Center.
+ * Original Author: Eric Bjorklund  (was called mrfSyncIO.h)
+/*  Required Header Files        */
+/* This is needed on vxWorks 6.8 */
+#ifndef _VSB_CONFIG_FILE
+#  define _VSB_CONFIG_FILE <../lib/h/config/vsbConfig.h>
+#endif
+#include  <vxWorks.h>                           /* vxWorks common definitions                     */
+#include  <sysLib.h>                            /* vxWorks System Library Definitions             */
+#include  <version.h>                           /* vxWorks Version Definitions                    */
+#include  <epicsTypes.h>                        /* EPICS Common Type Definitions                  */
+#include  <epicsEndian.h>                       /* EPICS Byte Order Definitions                   */
+ * vxAtomicLib.h (which defines the memory barrier macros)
+ * is available on vxWorks 6.6 and above.
+#if _WRS_VXWORKS_MAJOR > 6
+#  include  <vxAtomicLib.h>
+#elif _WRS_VXWORKS_MAJOR == 6 && _WRS_VXWORKS_MINOR >= 6
+#endif
+/*  Function Prototypes for Routines Not Defined in sysLib.h                                      */
+#ifdef __cplusplus
+extern "C" {
+#endif
+epicsUInt16 sysIn16    (volatile void*);                 /* Synchronous 16 bit read               */
+epicsUInt32 sysIn32    (volatile void*);                 /* Synchronous 32 bit read               */
+void        sysOut16   (volatile void*, epicsUInt16);    /* Synchronous 16 bit write              */
+void        sysOut32   (volatile void*, epicsUInt32);    /* Synchronous 32 bit write              */
+#ifdef __cplusplus
+#endif
+#  define be16_to_cpu(X)  (X)
+#  define be32_to_cpu(X)  (X)
+#  define le16_to_cpu(X) bswap16(X)
+#  define le32_to_cpu(X) bswap32(X)
+#  define be16_to_cpu(X)  bswap16(X)
+#  define be32_to_cpu(X)  bswap32(X)
+#  define le16_to_cpu(X)  (X)
+#  define le32_to_cpu(X)  (X)
+#else
+#endif
+#define ioread8(address)           sysInByte   ((epicsUInt32)(address))
+#define iowrite8(address,data)     sysOutByte  ((epicsUInt32)(address), (epicsUInt8)(data))
+#define nat_ioread16(address)      sysIn16 ((address))
+#define nat_ioread32(address)      sysIn32 ((address))
+#define nat_iowrite16(address,data) sysOut16(address,data)
+#define nat_iowrite32(address,data) sysOut32(address,data)
+#define be_ioread16(address)       be16_to_cpu (sysIn16 ((address)))
+#define be_ioread32(address)       be32_to_cpu (sysIn32 ((address)))
+#define be_iowrite16(address,data) sysOut16    ((address), be16_to_cpu((epicsUInt16)(data)))
+#define be_iowrite32(address,data) sysOut32    ((address), be32_to_cpu((epicsUInt32)(data)))
+#define le_ioread16(address)       le16_to_cpu (sysIn16 ((address)))
+#define le_ioread32(address)       le32_to_cpu (sysIn32 ((address)))
+#define le_iowrite16(address,data) sysOut16    ((address), le16_to_cpu((epicsUInt16)(data)))
+#define le_iowrite32(address,data) sysOut32    ((address), le32_to_cpu((epicsUInt32)(data)))
+#ifndef VX_MEM_BARRIER_R
+#  define VX_MEM_BARRIER_R() do{}while(0)
+#endif
+#ifndef VX_MEM_BARRIER_W
+#  define VX_MEM_BARRIER_W() do{}while(0)
+#endif
+#ifndef VX_MEM_BARRIER_RW
+#  define VX_MEM_BARRIER_RW() do{}while(0)
+#endif
+#define rbarr()  VX_MEM_BARRIER_R()
+#define wbarr()  VX_MEM_BARRIER_W()
+#define rwbarr() VX_MEM_BARRIER_RW()
Re: [Merge] lp:~epics-core/epics-base/devlib2mmio into lp:epics-base Ben Franksen
Re: [Merge] lp:~epics-core/epics-base/devlib2mmio into lp:epics-base Andrew Johnson
Re: [Merge] lp:~epics-core/epics-base/devlib2mmio into lp:epics-base mdavidsaver
Prev: Re: tool_lib.c -- next attempt Eric Norum
Next: EPICS support through the latest Manufacturing Innovation Institutes announced by Obama Lewis, Christopher L.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] lp:~epics-core/epics-base/devlib2mmio into lp:epics-base Ben Franksen
ANJ, 30 Nov 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
