2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/devlib2mmio into lp:epics-base
To: mdavidsaver <[email protected]>
Date: Thu, 21 Nov 2013 17:48:18 -0000
Review: Needs Fixing
Michael, I'd like to merge this branch (I know, finally!), but there's no code in Base that actually uses the macros that it defines, so I don't know whether code using it would even compile for all our supported targets. If it had a test program that instantiated all the routines we would know that it compiles everywhere and can be linked into an executable that can be loaded. It also needs an announcement in the Release Notes, and documentation for the API in the Application Developers Guide (section 20.21 could probably use a major overhaul anyway).
https://code.launchpad.net/~epics-core/epics-base/devlib2mmio/+merge/163365
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
[Merge] lp:~epics-core/epics-base/devlib2mmio into lp:epics-base mdavidsaver
Prev: Re: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base Jeff Hill
Next: [Merge] lp:~johill-lanl/epics-base/ca-ref-man-maint into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] lp:~epics-core/epics-base/devlib2mmio into lp:epics-base Ben Franksen
Next: Re: [Merge] lp:~epics-core/epics-base/devlib2mmio into lp:epics-base mdavidsaver
ANJ, 30 Nov 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
