2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: macLib semantics should be documented somewhere
To: <[email protected]>
Date: Thu, 22 Aug 2013 16:00:57 +0200
We recently compiled msi (a patched version but that is not the point here)
with R3.14.12.2 and stumbled over the "recursive" and "undefined" keywords
that the macLib seems to insert when expanding, respectively, recursive or
undefined macros. I remembered this being talked about on tech-talk at one
time but I could not find the thread in the archives. So I tried to find
documentation about this somewhere. I looked into the Application Developer's
Guide, the release notes, and the file macLibREADME in the sources, all to no
avail. We even looked at the changeset comments using the bazaar web interface
(3.14 branch). It appears this change was introduced along with the
introduction of scoping in the macLib, but the comment did not say so.
Anyway, the main intent of this message is not to complain, but rather to
(politely) request that some documentation for the macLib is added somewhere,
ideally in the Application Developer's Guide (which already contains a section
on the macLib but only lists the exported procedures). The macLibREADME is
probably a good starting point, but it would need to be updated to include the
latest changes.
Thanks
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: macLib semantics should be documented somewhere Andrew Johnson
Prev: Multiple Instances of JCA on Same Computer? Olson, Thomas C.
Next: [Bug 641365] Re: Incorporate macLibREADME text into 19.16 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: macLib semantics should be documented somewhere Andrew Johnson
