2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 641365] Re: Incorporate macLibREADME text into 19.16
To: [email protected]
Date: Thu, 22 Aug 2013 18:00:57 -0000
Additional text is needed to cover sub-macros $(name=default, sub=value,
sub2) and document the library's response to recursive and undefined
macros.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Application Developers'
Guide.
https://bugs.launchpad.net/bugs/641365
Title:
Status in EPICS Application Developers' Guide:
  New
Bug description:
  There is text in base/src/libCom/macLib/macLibREADME that can probably
  go straight into the appDevGuide, section 19.16.  The wording in
  macLibNOTES needs a bit of rewriting but what it discusses should also
  be covered in there somewhere.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-appdev/+bug/641365/+subscriptions
Prev: macLib semantics should be documented somewhere Benjamin Franksen
Next: Re: macLib semantics should be documented somewhere Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: macLib semantics should be documented somewhere Benjamin Franksen
Next: Re: TSEL question Ralph Lange
