I cast my vote with Benjamin. Keep the strict string comparisons and provide better diagnostic messages.
Question for core developers: Should we modify the Enum string parser to try using case-independent or other fuzzy string comparisons if a string value doesn't match using the case-dependent comparison or after trying to convert the string to an integer?
We could make the IOC dwim ("do what I mean", a Perl term) in the case below, but the result is a less precise database so I'm not sure if this is a good idea or not and how far we should take it.
- Andrew
Sent from my iPad
Begin forwarded message:
On 08.10.2013 18:05, Christian Pauly wrote:
field(OMSL, "CLOSED_LOOP")
Any idea what i am doing wrong ?
This is the last piece i am missing to get it running...
It is not "CLOSED_LOOP" but "closed_loop". You should see an error message when loading the record and a caget on the OMSL field should show that it is still "supervisory".
Dirk
- Enumerated string comparisons Johnson, Andrew N.
Re: Enumerated string comparisons Michael Davidsaver
<2013>
2025
2026
Re: Enumerated string comparisons Benjamin Franksen
[Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Ralph Lange
<2013>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
