2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Enumerated string comparisons
Date: Wed, 9 Oct 2013 16:38:53 +0000
Question for core developers: Should we modify the Enum string parser to try using case-independent or other fuzzy string comparisons if a string value doesn't match using the case-dependent comparison or after trying to convert the string to an integer? We could make the IOC dwim ("do what I mean", a Perl term) in the case below, but the result is a less precise database so I'm not sure if this is a good idea or not and how far we should take it.
- Andrew
Sent from my iPad
Begin forwarded message:
Date: October 8, 2013, 11:50:11 PM PDT
To: Christian Pauly <[email protected]>
Subject: Re: how to issue a shell command from EPICS record ?
On 08.10.2013 18:05, Christian Pauly wrote:
field(OMSL, "CLOSED_LOOP")
Any idea what i am doing wrong ?
This is the last piece i am missing to get it running...
It is not "CLOSED_LOOP" but "closed_loop". You should see an error message when loading the record and a caget on the OMSL field should show that it is still "supervisory".
Dirk
Re: Enumerated string comparisons Benjamin Franksen
Re: Enumerated string comparisons Eric Norum
Prev: Re: [Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base mdavidsaver
Next: Re: [Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Enumerated string comparisons Benjamin Franksen
ANJ, 30 Nov 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
