2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base
To: Ralph Lange <[email protected]>
Date: Sat, 30 Nov 2013 19:29:26 -0000
> could you push the documentation to a branch in https://code.launchpad.net
> /epics-appdev ?
Done
lp:~mdavidsaver/epics-appdev/thread-pool
Also made some final cleanup of the API including the use enums instead of integers for the work functions mode and the epicsThreadPoolControl function option arguments.  The epicsJobSet function is removed in favor of a magic argument EPICSJOB_SELF to set the user pointer to the epicsJob*.  Also tweaked the default thread priority to run between highest CA server and the Medium scan.
https://code.launchpad.net/~epics-core/epics-base/thread-pool/+merge/108385
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
Re: [Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base Ralph Lange
Prev: Re: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base Andrew Johnson
Next: [Merge] lp:~epics-core/epics-base/postdbrprop into lp:epics-base mdavidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base Ralph Lange
Next: Enumerated string comparisons Johnson, Andrew N.
ANJ, 30 Nov 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
