2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Enumerated string comparisons
To: <[email protected]>
Date: Wed, 9 Oct 2013 20:17:03 +0200
Hi Andrew
Am Mittwoch, 9. Oktober 2013, 16:38:53 schrieb Johnson, Andrew N.:
> Question for core developers: Should we modify the Enum string parser
> to try using case-independent or other fuzzy string comparisons if a
> string value doesn't match using the case-dependent comparison or
> after trying to convert the string to an integer? We could make the
> IOC dwim ("do what I mean", a Perl term) in the case below, but the
> result is a less precise database so I'm not sure if this is a good
> idea or not and how far we should take it.
I share your reservations about making the parser more dwim. My main
objective is that it makes the specification more complex. I like a
nice, clean spec that allows independent (and still correct)
implementations. Case insensitivity for enum strings would be fine with
me, but I would definitely stop there.
An alternative is to give better error messages. For instance, propose
alternatives based on some similarity heuristics. Taking the example
below, a message like
  "CLOSED_LOOP" is not a valid value for the enumeration "menuOmsl",
  which is the type of the field "OMSL" in record "xxx".
  Perhaps you meant "closed_loop"?
would, I think, make the whole thing crystal clear, even to a newcomer.
Cheers
Ben
> Begin forwarded message:
> From: Dirk Zimoch <[email protected]<mailto:[email protected]>>
> Date: October 8, 2013, 11:50:11 PM PDT
> To: Christian Pauly
> Cc: EPICS Tech Talk
> <[email protected]<mailto:[email protected]>> Subject: Re:
> how to issue a shell command from EPICS record ?
> On 08.10.2013 18:05, Christian Pauly wrote:
> field(OMSL, "CLOSED_LOOP")
> Any idea what i am doing wrong ?
> This is the last piece i am missing to get it running...
> It is not "CLOSED_LOOP" but "closed_loop". You should see an error
> message when loading the record and a caget on the OMSL field should
> show that it is still "supervisory".
> Dirk
"Make it so they have to reboot after every typo." -- Scott Adams
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: Enumerated string comparisons Michael Davidsaver
Enumerated string comparisons Johnson, Andrew N.
Prev: Re: [Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base Ralph Lange
Next: Re: Enumerated string comparisons Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Enumerated string comparisons Johnson, Andrew N.
