Hi Ben,
On 09/28/2013 06:10 PM, Benjamin Franksen wrote:
I have just pulled from the 3.15 branch and get build errors when using
parallel make. The error is well hidden among all the warnings so I
added some markup in the output below.
I think we have now fixed those particular sources of parallel build
problem, please try again with the latest 3.15 branch.
By the way, the dbdExpand.pl script now detects missing include files
and suggests a build dependency rule for a Makefile that should fix some
parallel build problems. This technique could be introduced to the
other dbd*.pl scripts if it proves useful, although I don't think they
are likely to be as prone to the problem.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Build problem with 3.15-head Benjamin Franksen
casStrmClient.cc memory leak fix Hill, Jeff
EPICS Mutex exceptions with file & line Andrew Johnson
<2013>
2025
2026
Re: [Merge] lp:~epics-core/epics-base/printf-record into lp:epics-base Andrew Johnson
<2013>
2025
2026
