2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS Mutex exceptions with file & line
To: EPICS core-talk <[email protected]>
Date: Mon, 21 Oct 2013 17:59:40 -0500
Jeff: this is mostly your code being modified, you might want to respond if you object.
All: Currently C++ code that creates an epicsMutex object doesn't provide any source code location information, even though the epicsMutex class can save that and report it in certain error messages. I developed the attached patch to improve that, does anyone have any better ideas than the newEpicsMutex macro it introduces, or any other objections to merging this patch?
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
=== modified file 'src/libCom/osi/epicsMutex.h'
--- src/libCom/osi/epicsMutex.h	2009-01-06 17:07:56 +0000
+++ src/libCom/osi/epicsMutex.h	2013-07-08 19:09:08 +0000
@@ -23,11 +23,14 @@
 #include "compilerDependencies.h"
+#define newEpicsMutex new epicsMutex(__FILE__,__LINE__)
 class epicsShareClass epicsMutex {
 public:
     class mutexCreateFailed; /* exception payload */
     class invalidMutex; /* exception payload */
     epicsMutex ();
+    epicsMutex ( const char *pFileName, int lineno );
     ~epicsMutex ();
     void show ( unsigned level ) const;
     void lock (); /* blocks until success */
=== modified file 'src/libCom/osi/epicsMutex.cpp'
--- src/libCom/osi/epicsMutex.cpp	2012-06-22 22:32:10 +0000
+++ src/libCom/osi/epicsMutex.cpp	2013-07-08 19:00:01 +0000
@@ -226,6 +226,14 @@
+epicsMutex :: epicsMutex ( const char *pFileName, int lineno ) :
+    id ( epicsMutexOsiCreate (pFileName, lineno) )
+    if ( this->id == 0 ) {
+        throw mutexCreateFailed ();
 epicsMutex ::~epicsMutex ()
     epicsMutexDestroy ( this->id );
=== modified file 'src/ca/client/ca_client_context.cpp'
--- src/ca/client/ca_client_context.cpp	2013-06-07 23:08:38 +0000
+++ src/ca/client/ca_client_context.cpp	2013-07-08 18:58:05 +0000
@@ -57,7 +57,7 @@
     caClientCallbackThreadId = epicsThreadPrivateCreate ();
     assert ( caClientCallbackThreadId );
-    ca_client_context::pDefaultServiceInstallMutex = new epicsMutex;
+    ca_client_context::pDefaultServiceInstallMutex = newEpicsMutex;
     epicsAtExit ( cacExitHandler,0 );
=== modified file 'src/ca/legacy/gdd/gdd.cc'
--- src/ca/legacy/gdd/gdd.cc	2011-11-29 22:14:19 +0000
+++ src/ca/legacy/gdd/gdd.cc	2013-07-08 18:57:59 +0000
@@ -79,7 +79,7 @@
 extern "C" void gddStaticInit ( void * p )
     epicsMutex * * pMutex = static_cast < epicsMutex * * > ( p );
-    *pMutex = new epicsMutex ();
+    *pMutex = newEpicsMutex;
 gdd::gdd(int app, aitEnum prim, int dimen)
=== modified file 'src/ca/legacy/gdd/gddNewDel.h'
--- src/ca/legacy/gdd/gddNewDel.h	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/gdd/gddNewDel.h	2013-07-08 19:06:27 +0000
@@ -64,7 +64,7 @@
         char** x = (char**)pfld; return *x; } \
     void newdel_setNext(char* n) { char* pfld = (char *)&fld; \
         char** x=(char**)pfld; *x=n; } \
-    static void gddNewDelInit (void) { pNewdel_lock = new epicsMutex; }
+    static void gddNewDelInit (void) { pNewdel_lock = newEpicsMutex; }
 // declaration of the static variable for the free list
=== modified file 'src/libCom/cxxTemplates/epicsSingletonBase.cpp'
--- src/libCom/cxxTemplates/epicsSingletonBase.cpp	2010-10-05 19:27:37 +0000
+++ src/libCom/cxxTemplates/epicsSingletonBase.cpp	2013-07-08 18:57:20 +0000
@@ -33,7 +33,7 @@
 static void epicsSingletonOnce ( void * )
-    pSingletonBaseMutexEPICS = new epicsMutex;
+    pSingletonBaseMutexEPICS = newEpicsMutex;
     epicsAtExit ( epicsSingletonCleanup,0 );
=== modified file 'src/libCom/cxxTemplates/epicsSingletonMutex.cpp'
--- src/libCom/cxxTemplates/epicsSingletonMutex.cpp	2010-10-05 19:27:37 +0000
+++ src/libCom/cxxTemplates/epicsSingletonMutex.cpp	2013-07-08 19:06:07 +0000
@@ -35,7 +35,7 @@
     // This class exists for the purpose of avoiding file scope
     // object chicken and egg problems. Therefore, pEPICSSigletonMutex
     // is never destroyed.
-    pEPICSSigletonMutex = new epicsMutex;
+    pEPICSSigletonMutex = newEpicsMutex;
 void SingletonUntyped :: incrRefCount ( PBuild pBuild )
=== modified file 'src/libCom/misc/ipAddrToAsciiAsynchronous.cpp'
--- src/libCom/misc/ipAddrToAsciiAsynchronous.cpp	2012-04-12 16:28:23 +0000
+++ src/libCom/misc/ipAddrToAsciiAsynchronous.cpp	2013-07-08 19:06:20 +0000
@@ -155,7 +155,7 @@
 static void ipAddrToAsciiEngineGlobalMutexConstruct ( void * )
-    ipAddrToAsciiEnginePrivate :: pGlobalMutex = new epicsMutex ();
+    ipAddrToAsciiEnginePrivate :: pGlobalMutex = newEpicsMutex;
     epicsAtExit ( ipAddrToAsciiEngineShutdownRequest, 0 );
Prev: Re: Build problem with 3.15-head Andrew Johnson
Next: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: casStrmClient.cc memory leak fix Hill, Jeff
Next: [Merge] lp:~epics-core/epics-base/parallel-cbthreads-2 into lp:epics-base Ralph Lange
