Hello All,
I was having a closer look at the recent changes in R3.15; my perception is that behavior has changed and that in an out-of-memory situation R3.15 is currently discarding the update for the event queue instead of the original behavior which was replacing the last entry on the queue for the subscription that was being posted, in an out-of-memory situation.
Should I submit a defect report; or perhaps this was this an intentional behavior change in R3.15?
Ref: in the code below if db_create_event_log returns null due to out-of-memory condition then db_post_events is a noop.
int db_post_events(
void *pRecord,
void *pField,
unsigned int caEventMask
struct dbCommon * const prec = (struct dbCommon *) pRecord;
struct evSubscrip *pevent;
if (prec->mlis.count == 0) return DB_EVENT_OK; /* no monitors set */
LOCKREC (prec);
for (pevent = (struct evSubscrip *) prec->mlis.node.next;
pevent; pevent = (struct evSubscrip *) pevent->node.next){
* Only send event msg if they are waiting on the field which
* changed or pval==NULL and waiting on alarms and alarms changed
if ( (dbChannelField(pevent->chan) == (void *)pField || pField==NULL) &&
(caEventMask & pevent->select)) {
db_field_log *pLog = db_create_event_log(pevent);
pLog = dbChannelRunPreChain(pevent->chan, pLog);
if (pLog) db_queue_event_log(pevent, pLog);
UNLOCKREC (prec);
return DB_EVENT_OK;
- RE: db_create_event_log Hill, Jeff
Re: [Merge] lp:~epics-core/epics-base/parallel-cbthreads-2 into lp:epics-base mdavidsaver
posting DBE_PROPERTY Michael Davidsaver
<2013>
2025
2026
<2013>
2025
2026
