Subject: |
Re: [Merge] lp:~johill-lanl/epics-base/ca-ref-man-maint into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
Jeff Hill <[email protected]> |
Date: |
Thu, 07 Nov 2013 23:56:21 -0000 |
Review: Approve
Now the original apostrophes (' = 0x27) have been replaced by a back-quote character (` = 0x60) which is just as wrong as the right-single-quote HTML entity was.
Many HTML entities such as © and ü in the original have also been replaced by single character equivalents, which are correct for the iso-8859-1 charset that the HTML head block says that the file uses, but I much prefer that we use entities for all non-ASCII characters so there is no danger of problems if someone edits the file in a UTF-8 editor or using some other code-page. I'm not sure what editor you're using for this, but please try to configure it to use HTML entities in preference to all characters outside of the common 7-bit range.
However I have extracted your changes by hand, undone the apostrope and entity stuff and merged the rest into the 3.14 version of CAref.html. They will appear in the 3.15 version in due course (Bazaar is currently having a little difficulty with merging the 3.14 branch into 3.15). The result also contains a few other changes that we have made to the file since you last worked on it.
https://code.launchpad.net/~johill-lanl/epics-base/ca-ref-man-maint/+merge/53647
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
Re: posting DBE_PROPERTY Michael Davidsaver
Build failed in Jenkins: epics-base-3.15 #27 APS Jenkins
<2013>
2025
2026
Re: [Merge] lp:~johill-lanl/epics-base/ca-ref-man-maint into lp:epics-base Jeff Hill
<2013>
2025
2026
